gerwin wrote:So the theory is that under some circumstances the CPU can accept all defined multipliers (does that mean 5.5x max?).
Not quite! I have taken my P2-400 three times into this unlocked state, where I could enter the bios, change the multi or fsb at will as long as I used ctrl-alt-del and not reset or power button. I could run at 500 MHz @ fsb100. I ended these states by trying the 1.5x and 5.5x multi. The systems hangs and needs a reset.
I have never seen a P2 run at 5.5x. My own P2-333 doesn't run at 5.5x either. I doubt this multi even exists. What evidence do we have for its existance?
Most important is that each of the three semi-unlocked deschutes will offer a range of 133 to 350 or 400 MHz. Which remains so even when the multipliers refuse to go above their default.
Yes, and that is the main reason why I haven't yet taken the soldering iron to try something more dramatic with a disposable MB. Even if limited to 4x, I can reach 133MHz to 448MHz from bios.
Why do you want the multipliers above that released? is it because you want the top speed to be 4.5x100MHz? just curious.
We both know that 450+ can be done by fsb too. No, I am curious as to why my p2 acts differently from tetriums. I doubt they are any different.
sliderider wrote:And here I thought the purpose of these forums was to get old DOS games to run at normal speeds on newer hardware. Silly me. 😖
You got the purpose right but you seem to have difficulty seeing the most flexible solution.
