Asus 486 mobo PVI-486SP3
Reply 40 of 43, by jesolo
5u3 wrote:
IIRC (it's been five years), the main issue was that ctrl-alt-del resets didn't work any more when the CPU was in protected mode.
I can confirm that. Ctrl+Alt+Del warm boot doesn't work when in protected mode.
However, I suppose I can just use the reset switch if I want to reboot.
Otherwise, I can probably fall back to revision 3.06 but, then I have the y2k bug again.
Reply 42 of 43, by jesolo
smeezekitty wrote:
Other than fail Y2K tests, does the Y2K bug really affect anything?
Probably not.
I actually decided to revert back to BIOS revision 3.06 and, based on system board tests I've performed, the BIOS (and DOS) are keeping the correct date and time.
