First post, by RogueTrip2012
- Oldbie
Hi again. So I recapped an old MSI MS-6309 today and got windows98se installed on it.
Everything is fine except that I cannot find drivers for the Audigy 2 SB0240 that install everything. I did find a set of WDM that will atleast install the audio processor and the 1394 firewire driver.....but not a "PCI Input Controller" I assume it might be the SB16 Emulation?
Sound will work with these WDMs I found.
Are there any of Daniel K packs that work with the Audigy 2 and windows98se? or Soft-modded drivers?
Here is the system build:
Pentium III 733MHz
MSI MS-6309
256MB PC-133
Voodoo 5 5500AGP
DFI 10/100 nic card
Soundblaster Audigy 2 SB0240
40GB Samsung HDD
Samsung 52x CDRW 8mb buffer
TIA!
