bushwack wrote:Are you using a TV or what for that resolution? I just dont understand why you would have invested in a pretty powerful comp to run last decade resolutions.
Nope it's a 18.5" Acer LCD. This model can do 75 Hz which is very very important, because I use V-sync.
With 60 Hz V-sync you get noticeable input lag, 75Hz is much better. My next LCD will likely be a 120Hz model though.
That's the thing, I didn't invest much. I'm a penny pincher. The GTX460 (it's the 768 model) got really cheap over here in Australia (A$ 149) and my CPU is a phenom 555 which fully unlocks into a quad. I usually buy my times when manufacturers are very competitive or there is a part that has outstanding performance per dollar (like an unlocked 555).
The mainboard is the most basic ASUS uATX board.
To me it's a smart selection of components and the choice of LCD gives me ~ double the fps compared to a Full HD screen.
The GTX460 might be fine for you at FullHD, but I know myself pretty well, I wouldn't be satisfied and would be forced to buy a power hungry, hot, loud and expensive card.
Once we see the new 28nm products I might upgrade...
