Reply 60 of 147, by sgt76
- Oldbie
Sorry RG100, must have gone to bed when your next posts came in. I think I faced the same issue doing the wire trick before too, on which ones are VSS and VID2. I too used both sites for reference, can't remember which one though for the Soyo. I used Martin's exclusively for my AX33 Pro board- cranked that one up to 2.05v.
Congrats also on your super overclock- though by now this is business as usual for you! 🤣
wrote:Tualatin chips and especially the boards were never common here in The Netherlands either. My guess is that there were simply ne […]
Tualatin chips and especially the boards were never common here in The Netherlands either. My guess is that there were simply never that many made and on top of that, it was the start of the capacitor plague. The Tualatin boards I did find often had leaking caps and one other board (an ASUS TUSL2-C) had this annoying whining from one of it's coils. I ended up giving the board away, even though it seemed to work perfectly.
The Tualatin chips I found were usually Tualerons 1.2 and 1.3 and only once did I find a Tualatin P3 1.2. I never actually found any of the P3-s's in the wild but thankfully they are being sold cheaply on Ebay these days, NOS 😀I've recently gotten an ECS board (yukky) and the only reason it didn't disappear on the bottom of my stash right away is because the board happens to support Tualatins! 😜
I'd even be happy if a Compaq Tualatin board happened to find it's way into my hands 🤣
Of the Tualatin boards, over here it seems that the TUSL2-C's are the most common ones.
Tualatins were expensive when new and gaming performance is still below even a sub 2ghz P4, despite the excitement of having a 1ghz + P3 system. I too only have managed to find a Tualeron 1.2, which unfortunately only overclocks to 112mhz stably. At that speed, it doesn't seem to be faster than an overclocked coppermine- at most it's equal due to the low bus speed.
But the 1.4S at 1740mhz is a whole different animal though- RG100 could you pls do some benchies against a P4 or Athlon XP? I'd be very much interested to see how really does a 1.74 ghz PIII stack up against a P4 or similar.
