First post, by F2bnp
- l33t
Hey guys, after reading a lot about these Aureal cards, I decided to buy one. I got the Videologic Sonic Vortex 2 and I even managed to strike a good deal (5 pounds shipped 😁). So naturally, I installed it on my Retro system using the 2048 reference drivers. I got a message saying something along the lines "your sound card is not connected to your primary PCI port. Due to this Sound Blaster emulation, Gameport support and MPU401 might not work". Then thing is, the driver for the above things would not install at all. I didn't really bother yet, I thought I just had to install the card to the first PCI slot, so I just ignored it at the time.
I played Jedi Knight and Half-Life using the card but the 3D effect wasn't really working, despite that it was working on the A3D Demos (I think). I tried using headphones, same stuff, it just wasn't working correctly. Jedi Knight had sounds fading and stuff and Half-Life made absolutely no difference from the vanila "2D" sound.
I then read that the PCI slot thing is a chipset related problem. Intel chips like the i810 and i815 produce this bug and to avoid it you have to remove a semicolon from one of the inf files in order to disable Bus Detection.
So I did just that, reinstalled the drivers and I was ready to be blown off. 3D sound did the same thing, but now I could normally use my daughterboard and Soundblaster FM synthesis and Digital Effects. However, each and every time I tried to boot into Win98 DOS, the system would hang with a blinking DOS cursor. At one point I tried to shut the computer down normally and the system would hang at the "Windows 98 is shutting down" screen.
I tried using a completely default autoexec.bat and config.sys. Same result. I tried using 2041 and 2050 drivers. Same stuff. What the hell is wrong!
My system is a Pentium 3 1GHz on an Asus CUSL2, 256MB RAM, a GeForce2 Ti, Voodoo 2 SLI and the Vortex 2 card. Oh and Windows 98SE
