First post, by amstrad1640
I've upgraded my Hewlett packard Vl2 4/66 i486 66mhz to an Amd 5x86 133mhz but i have a problem, only x3 can be used and i can to have only 100mhz (3x33). I've tried some jumper
There is only 25 or 33 for Fsb on the board and the manual, but i find a jumber who 's doing 50 fsb. It isnt on the manual.
Now i have a 5x86 150mhz but i have a litle bug on the boot "486Dx 200mhz"lol
On dos etdiag (evergreen tool) it's really a 5x586 150 (5x50)
The system is fast but with l2 cache (i dont have the upgrade on the board) it will be more fast 😉
speedtest 56
Bye.
Ps: Why can't i to use x4?
Reply 2 of 5, by amstrad1640
A don't have jumper for x2 , x3 or x4. it's auto detect, when i put a 486 dx2 66 it's ok (2x33), a pentium overdrive too (2.5x33) or a 486dx4 100 (3x33), i don't need jumper for, just change the CPU.
why the amd 5x86 133 can't to use x4 without jumper? i have the same problem when i put it on a msi 4144 board, never run to 133 only 100...
Reply 3 of 5, by sliderider
It's to maintain back compatibility with older motherboards that may not have a 4x jumper. Your machine was built before the 5x86 was made so it doesn't know what to do with it other than use the 3x setting that the DX4 chips used. A BIOS update might help, but I can't guarantee that. I don't know if HP maintains their support database files for machines that old, but you can try.
You may also need an upgrade adapter to use that CPU in that machine like the ones Evergreen made.
According to this, your MSI motherboard doesn't support the 5x86 natively. you'd likely need an adapter for that one, too.
http://stason.org/TULARC/pc/motherboards/M/MI … 86-MS-4144.html
Reply 4 of 5, by Tetrium
Anyone think it would still be possible to attain 133Mhz by using one of those upgrade chips? Those often came with jumpers of their own 😉
Like the Kingston Turbochip or the Evergreen
My retro rigs (old topic)
Report spammers here!
Reply 5 of 5, by amstrad1640
Yes!
There is 3 jumper on Evergreen 5x86 133 (1 have them on my 2 vlb 486 computers )
On old 5v 386/486 vlb board and On a 486vlb 3.3v /5v i change it with a 3v 5x86 133/ 150 (3x50) i can't to have x4 (again 🙁 ) for 133 or 160 😉
One is detected at 120, but it's only on boot (i can't to update bios to have to the real name / speed), on dos with etdiag i have 4 x 33 =133 😀
The 3 jumpers are:
-WB or WT
-x3
-x2 / x4
