The World's Fastest 486
Reply 440 of 767, by The Serpent Rider
Water won't help, it operates well above zero Celsius mark, which may be crucial for stability. You can wait for winter and achieve similar or better results near open window without fancy peltier module.
But it seems that CPU-Galaxy has reborn it
In that case I take credit as main instigator for CPU-Galaxy video =P
Reply 441 of 767, by H3nrik V!
The Serpent Rider wrote on 2021-05-25, 14:17:
Sorry if I wasn't clear .. I meant water cooling the warm side of the peltier, to keep it even more steady 😉 Typically the peltier doesn't keep more than a maximum of 40C difference between warm and cold side, and when cooling a CPU will quickly get the warm side above 50C ..
Reply 442 of 767, by ludov p
Is parity ram neccesarry for OC in this situation? I see fopeia mention he uses it on his FPM RAM, ut it's getting harder to get hold of one 64MB stick og 60ns, parity FPM RAM. And what about the difference between EDO and FPM, any comments there apart from the ones mentioned in this thread already? I've tried many sticks of each type already, but will have to do more tweaking on the rig to conclude what works best in my setup.
Reply 443 of 767, by pshipkov
LuckyStar likes EDO better than FPM.
Opposite seems to be the case for Biostar UUD.
retro bits and bytes
Reply 444 of 767, by feipoa
I don't think I have any 486 which 'needs' parity. It just so happens that my "magic" 64 MB, gold-plated, Samsung 72-pin sticks are parity. I normally have parity disabled because soft resets can spit out an error.
Reply 445 of 767, by maxtherabbit
pshipkov wrote on 2021-05-29, 18:17:
What? My SiS 496 silicon doesn't work with EDO at all. I doubt the version that does accept it would work "better"
Reply 446 of 767, by lukas12p
maxtherabbit wrote on 2021-05-30, 16:19:
Which revision of LS-486 board do You have?
Reply 447 of 767, by maxtherabbit
lukas12p wrote on 2021-05-30, 16:51:
C2
Reply 448 of 767, by lukas12p
maxtherabbit wrote on 2021-05-30, 17:31:
C2
I have few rev.C2 boards and all works faster with EDO memory
Reply 449 of 767, by lukas12p
I have put 50ns EDO ram and now get 21,4 fps in Quake and 64,9 fps in Doom, with Matrox graphic card and PCI@33MHz.
Looks like next limit is cache, but I have only those fake 10 ns ones..
CPU runs at temperature 2 deg. C.
Reply 450 of 767, by maxtherabbit
Unfortunately my 5x86 isn't stable at 200, but here is the best I could muster at 3x50MHz using FPM.
Btw it's not the revision of the motherboard that dictates EDO support, it's the revision of the northbridge.
The attachment 20210426_200057.jpg is no longer available
Reply 452 of 767, by maxtherabbit
ViTi95 wrote on 2021-06-13, 21:49:
My AMD 5x86 (3x50) is able to get 17.4 fps in Quake, even with very bad L2 cache timings (15ns 256Kb). And I think I can do even better *evil face*.
Spoiler
https://github.com/viti95/486Quake/
I take it this is running on some kind of Quake source port?
I'm able to manage 16.7fps at 3x50 using a Millennium on vanilla quake (Phil's pack)
Reply 453 of 767, by pshipkov
It is possible. With Asus VLI gx4 + ark1000vl + 4x40mhz I get over 18 fps.
With those late pci 486 boards at 180 it is around 19-20. One of the 180mhz capable cpus is actually magical. Can do it at 3.3v with air cooling.
At 200 it is 21-22, but not stable enough - my biggest heatsink is insufficient to keep up with the Peltier.
While replying here, finally motivated myself to splurge $25 for a proper one 😀
Reply 454 of 767, by ViTi95
maxtherabbit wrote on 2021-06-13, 23:55:
Spoiler
yep, I'm doing a port similar to FastDoom. My system gets 15.8 fps with stock Quake 1.06 (9% slower).
https://www.youtube.com/@viti95
Reply 455 of 767, by ph4nt0m
It doesn't matter what revision of LS-486E you have. Only SiS 496 of PR stepping supports EDO properly. Older steppings such as OR, NV, NU, MU do not.
My Active Sales on CPU-World
Reply 456 of 767, by feipoa
Which PCB revisions have the PR steppings been found on? I've seen them on Rev.D, but were there others?
Reply 457 of 767, by The Serpent Rider
C2 mostly.
Reply 458 of 767, by feipoa
Small update to check repeatability. L2 cache size and type matter. On the Biostar MB-8433UUD w/Quake 1.06
256K WT = 19.1 fps
512K WT = 19.5 fps
1024K WT = 19.8 fps
Surprisingly,
512K WB = 19.3 fps
I'm using 64 MB RAM, so I did not exceed the cacheable range with 512K WB, direct-mapped. Are results with double-banked L2 cache.
Reply 459 of 767, by appiah4
Wait, WT is faster on the 8433UUD? I didn't know, maybe I should revert to that and switch to 64MB RAM..
