First post, by amstrad1640
I can't to use a CMD648 IDE (100) controler on my 486 computer (POD 100 on PB4 abit PCI) to replace the onboard IDE.
I can to install it with boot on the onboard IDE in windows98se, i turn off computer .I connect the hardrive on the CMD486 IDE controler, i turn on computer and i disable harddrive in bios or i use auto detect, and i can to boot under Dos (windows98se dos 😉 ) but i can't to lauch windows 98se. Perhaps i must to disable udma, if i disable it, it's like the onboard IDE PB4 (i don't have driver to use it in winows98se...)
I can to lauch with onboard IDE + CMD648 IDE (>>without hardrive connected on it)
Bye.
