First post, by DonutKing
- Oldbie
So this is a little hard to explain, but basically on my 386 system I can hear background noise that seems to change based on what program is running, when the mouse is moving, and hard disk access.
Here's a video recording of the sound.
I am just in a menu, and you can hear a constant high pitched whine. It's not very noticable but its rapidly changing between two pitches. Also, when I move the mouse there is a faint, but noticable low buzzing (again, it might be hard to hear over the whine). You'll notice the noise seems to stop when I click the button to change menu pages.
So, has anyone got any ideas what might be causing this and a good way to stop it? It is audible in games but its harder to notice when there's sound over the top of it. (The volume was turned up pretty high for the video).
The system specs:
386DX40
MS-3124 motherboard
Sound Blaster Pro 2 CT1690, with attached Sony CDU33A
Roland LAPC-I
Conner 425MB IDE hard drive
Old AT 'L shaped' 200W PSU
ET4000AX
Some generic Super IO card with everything not necessary disabled.
ISA bus is running at 8MHz.
It happens with powered speakers and headphones so I know its not the speakers.
I've fiddled with volumes and the input/output filters on the SB PRO. All inputs disabled, and turning volumes to minimum makes no difference.
The LAPC-I doesn't have the noise on its output.
I've tried unplugging the CD ROM drive but no difference.
Different SB Pro, no difference.
Is it possible a problem with the power supply? Or maybe something not being earthed properly?
Could it be a mains issue? I've got the monitor, computer and speakers attached to the same surge protector/power board.
Any advice would be appreciated 😀
