First post, by keropi
- l33t++
Hiya!
If you remember from the other thread I am setting up a system around this mobo:
...and since I know little of OEM 386 era mobos I have more specific questions this time.... 😊
I have added a 16bit I/O controller (some goldstar one, plain looking) , a cirus 1MB vga and a sb-pro2... tried with a floppy all is booting fine and even played commander keen 4 just fine... until I put a HDD in the system.
Nomatter what I did although the BIOS was detecting correctly HDD's up to 8GB (tried 430MB/1.7GB/2GB and 20GB HDDS) I could not get DOS to boot or get the system see the HDD outside BIOS.
Then I found that changing the "F SEGMENT SHADOW RAM" option to Enabled or Cached (it was set at disabled) then the HDD would work fine, even the 20GB one with DiskManager overlay. Here is a BIOS pic with this option:
Now what does that have to do with HDD usage and OS loading? With this disabled the pc stays forever after the system summary screen, even floppy booting works for 4-5secs and then stalls forever...
(also when enabled I get a report that I have 64kb of Shadow Ram under the system summary , if I enable all items then the shadow ram size goes to 192kb IIRC)
Also the available values for this option (and all other Shadow Rams ones below it) are DISABLED / ENABLED / CACHED / IN 486 ... what value should I use? I triead Enabled and Cached and saw no difference (board has 128kb cache btw)
After overcoming the no-hdd-boot horror 😁 (and trying 3 different I/O cards just in case) I found that I cannot enable UMB blocks with URAM or HiRAM (or RDOSUMB) , they all complain more or less that the chipset is unknown and they cannot enable UMB.
Anyone knows of a UMB driver/enabler that will work with the Biotec 82C3491 mobo?
Lastly here are the 2 ISA nics that I have:
a 3COM Etherlink II TP rev.C and a GeniusLan K1306023 one. Are these NE2000 compatible so I can use the packet driver? I did a quick search for drivers and I got those lame driverguide spam/malware/install-awesome-program-to-update-drivers sites... meh
Haven't tested them yet but I believe the GeniusLan one would be better since it is 16bit and newer?
I know these are a lot of questions but I would greatly appreciate any help or tips or suggestions to try 😊
Thanks in advance!
