Help needed to identify this old card
First post, by sprcorreia
I have this card and i need to know if anyone knows the brand or model of it. It's an Adlib clone with midi port, VGA pass through and video out (i think, never tested).
Thank you.
Reply 1 of 28, by stbunny
Is there any marking on U10 IC?
P55T2P4, Intel Pentium 133MHz, 32Mb EDO, S3 Virge 325, YMF-719s + SC-55, AHA-2940U2W, ST39175LW, UltraPlex40Max, Opti USB PCI, Sony CPD-G400P 19"
Reply 2 of 28, by elfuego
I'd say it looks like a VGA capture card, or something similar. It doesnt look like a sound card to me...
Reply 3 of 28, by Anonymous Coward
Definitely not a VGA or capture card, the needed components just aren't there. It looks like an adlib clone with a nonstandard game port. The big chip is probably an OPL2.
Reply 4 of 28, by TheMAN
any FCC ID sticker on the back?
Reply 5 of 28, by DonutKing
I think its a Sound Blaster clone of some sort, its too complex to be merely an adlib clone, and I see IRQ jumpers down near the ISA connector.
I think the D-Sub connector is possibly a MIDI port.
I really don't think its a video or capture card of any description. On ISA video cards you usually see crystals to sync with the video frequencies and there's no video memory on it. Most of the chips on the board are just TTL logic chips or op-amps, not complex enough for a video adapter.
Reply 6 of 28, by RacoonRider
9235 is manufacture date, 35th week of 1992. But why 8-bit?
P.S. Maybe, FM radio? The plug on the top might be for antenna.
Reply 7 of 28, by stbunny
Or it can be oscilloscope main board. But maybe not...
Reply 9 of 28, by Jepael
The card seems to contain building blocks for an Adlib clone (UA010=OPL2, UA011=DAC, LM324=op-amp, LM386=speaker amp, backpanel has volume pot and audio output connector).
It also has seems to have a joystick interface (NE558 and pinheader for external DA-15 joystick connector).
It definitely has something to do with video as well. Maybe it takes in DE-15 VGA and outputs composite PAL video on RCA (the crystal reads 4.433619 which is a PAL color subcarrier frequency).
Most definitely it is not a SoundBlaster clone just because it has interrupt jumpers. The original Adlib card also had provisions for jumper selectable IRQ, but the pinheader for jumper was not mounted, so no interrupt could be selected unless a pinheader was soldered and a jumper placed there. Here the pinheader is mounted but no jumper so no IRQ is selected.
I do not believe it has MIDI port, simply no component would do it, if U10 converts video.
Reply 10 of 28, by luckybob
Jepael wrote:
The card seems to contain building blocks for an Adlib clone (UA010=OPL2, UA011=DAC, LM324=op-amp, LM386=speaker amp, backpanel […]
that's actually a 9 pin connector. in the 8 bit world, a 9 pin connector was "usually" a CGA monitor connector. Serial ports tended to be 25 pins at the time. "tended"
I would wager a guess, it is an ad-lib clone but with a CGA -> composite video converter. In theory, its just a simple DAC to go from cga to composite. It would make sense, if you are converting a tv to a monitor, that you would also have sound.
Reply 11 of 28, by sprcorreia
No markings. They were removed.
Adlib is working in DOS games, so it's partially a sound card and it has a game port connector on top left, i have the cable.
The port is VGA, and i have the cable too. I can connect it to a VGA card and it outputs normal image.
No sticker on the back unfortunately.
More pics tomorrow.
Reply 12 of 28, by 133MHz
U10 might then be a Sony CXA1645 or similar RGB encoder chip to convert VGA into PAL composite video in this case - seems like this card packs a bunch of stuff to sort of turn a PC into a games console (sound, joysticks, TV output). Very interesting I must say!
One thing I can't explain is what does it do about the horizontal scan rate since standard TVs won't like anything over 15 kHz. I know there are some TSRs for reprogramming certain VGA cards into outputting 15 kHz video, my guess is that this card may have come with one of those. The fact that the crystal oscillator is for PAL color makes it even more strange because of PAL's 50 Hz frame rate.
http://133FSB.wordpress.com
Reply 13 of 28, by leileilol
You could use it and dump its BIOS.
long live PCem
Reply 14 of 28, by 133MHz
I don't see anything resembling a ROM BIOS on the card.
Reply 15 of 28, by Jepael
Agree, definitely no ROM bios on that card.
And it seems the U10 might really be an CXA1645 (or clone) as suggested, based on pinout (pins 1 and 24 are ground, 6 is for colorburst crystal), but pics from the bottom side of the card are needed to verify this any further.
Reply 16 of 28, by sprcorreia
More pics as promised.
Reply 17 of 28, by Shagittarius
Some sort of MPEG decoder board?
Reply 18 of 28, by Anonymous Coward
I think we have a pretty good idea of what it is (adlib + game port + vga-->composite converter). The big question is what the purpose of it all is. For something supposedly made in 1992, why would it not have a DAC? It was suggested by another poster that it might be to convert a PC into an arcade machine. That's the only logical conclusion I've been able to come to as well.
Reply 19 of 28, by Jorpho
The "9235" seems just a little bit too prominent.
Googling turns up something called a "Videk 9235" that is referred to as a video splitter, but provides no further details.
