Socket A questions
First post, by cdoublejj
Does any one know of any after market Socket A coolers that work well? Does any one know about how well the old Athlon XP 2500+ overclocked?
EDIT: can any one tell me about these?
http://yaya-store.blogspot.com/2010/03/therma … -plate-for.html
Reply 1 of 49, by CapnCrunch53
I've got one of these, Thermaltake A1998: http://www.ebay.com/itm/Thermaltake-A1998-Cop … =item4d03c5c5ad
It's very cheap, and you just add your own 80mm fan. Unfortunately I haven't gotten to use it much as the Voodoo5 build it was going in has had so many problems and isn't running yet, but it is a very impressive heatsink in person. It's all copper, and the fins are really dense; I'm very confident that it will be a great cooler once I get my build working.
One issue I had with it though: the screws that shipped with it (used to install an 80mm fan) were actually the wrong size, so I ended up doing a slightly-ghetto fix by using some thin screws and nuts on the opposite end to hold the fan on. Minor inconvenience for an otherwise quality $8 cooler, but figured I should mention it.
PCs, Macs, old and new... too much stuff.
Reply 3 of 49, by elfuego
The one I have will allow you to reach at least 2.2Ghz (2.5 Ghz here) http://www.thermaltakeusa.com/Product.aspx?S=1135&ID=1554. Its silent and powerful. The only problem is - its big. It wont fit on all mainboards and in all computer cases.
Reply 4 of 49, by cdoublejj
Yeah I was thinking about the typhoon I have access to one. Not sure if the machine i would be using it on has the 754 holes. I was looking at the Ever Cool ND 18 it has a nice copper base with nice tall sharp fins and i was thinking it might not be to bad with with bigger fan and one of those funnel looking adapters.
Then again i was looking at a ton of coolers the other night.
So if a 2500+ is capable of 2.2 or even a massive 2.5 then i guess they were decent clockers no? I put presscot under water and got okay clocks and paired it with 3.5gb ram and an HD2600 and it runs rather well fora P4, I can only imagine a Barton core that is clocked.
Reply 5 of 49, by elfuego
They were fantastic clockers! Especially the 2500+ version which almost certainly could be overclocked to 3200+ (2.2Ghz) just by increasing the FSB. Even better, the mobile (-M) version could reach up to 2.7-2.8Ghz with some luck and some decent mainboard/PSU and cooling.
My barton-m at 2.5 Ghz is pretty limited by the mainboard (I'm using a soft-modded Abit KT7-a, KT133a chipset which doesnt officially support anything newer then Athlon XP 2000+). If I'd want to max out the CPU potential, I'd go for Nforce 2 ultra from DFI or Abit.
Reply 6 of 49, by swaaye
Rank Moderator
Moderator
Barton AXP-M chips are so cheap now. I like these chips mostly for their low temps. You can usually get a nice overclock while still keeping them under 1.65v. Cranking them to the edge with extra voltage, making them run 50% hotter, seems pointless now though.
Reply 8 of 49, by sklawz
Hi
Here is the CPU info for a BARTON (there is no SSE2/3):
> cat /proc/cpuinfo
processor       : 0
vendor_id : AuthenticAMD
cpu family : 6
model : 10
model name : AMD Athlon(tm) XP 3000+
stepping : 0
cpu MHz : 2171.656
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 mmx fxsr sse syscall mmxext 3dnowext 3dnow up
bogomips : 4343.31
clflush size : 32
cache_alignment : 32
address sizes : 34 bits physical, 32 bits virtual
power management: ts
> cpuid
 eax in    eax      ebx      ecx      edx
00000000 00000001 68747541 444d4163 69746e65
00000001 000006a0 00000000 00000000 0383fbff
80000000 80000008 68747541 444d4163 69746e65
80000001 000007a0 00000000 00000000 c1c3fbff
80000002 20444d41 6c687441 74286e6f 5820296d
80000003 30332050 002b3030 00000000 00000000
80000004 00000000 00000000 00000000 00000000
80000005 0408ff08 ff20ff10 40020140 40020140
80000006 00000000 41004100 02008140 00000000
80000007 00000000 00000000 00000000 00000001
80000008 00002022 00000000 00000000 00000000
Vendor ID: "AuthenticAMD"; CPUID level 1
AMD-specific functions
Version 000006a0:
Family: 6 Model: 10 [Duron/Athlon model 10]
Standard feature flags 0383fbff:
Floating Point Unit
Virtual Mode Extensions
Debugging Extensions
Page Size Extensions
Time Stamp Counter (with RDTSC and CR4 disable bit)
Model Specific Registers with RDMSR & WRMSR
PAE - Page Address Extensions
Machine Check Exception
COMPXCHG8B Instruction
APIC
SYSCALL/SYSRET or SYSENTER/SYSEXIT instructions
MTRR - Memory Type Range Registers
Global paging extension
Machine Check Architecture
Conditional Move Instruction
PAT - Page Attribute Table
PSE-36 - Page Size Extensions
MMX instructions
FXSAVE/FXRSTOR
25 - reserved
Generation: 7 Model: 10
Extended feature flags c1c3fbff:
Floating Point Unit
APIC
AMD MMX Instruction Extensions
Show last 31 lines
MMX instructions
FXSAVE/FXRSTOR
3DNow! Instruction Extensions
3DNow instructions
Processor name string: AMD Athlon(tm) XP 3000+
L1 Cache Information:
2/4-MB Pages:
Data TLB: associativity 4-way #entries 8
Instruction TLB: associativity 255-way #entries 8
4-KB Pages:
Data TLB: associativity 255-way #entries 32
Instruction TLB: associativity 255-way #entries 16
L1 Data cache:
size 64 KB associativity 2-way lines per tag 1 line size 64
L1 Instruction cache:
L2 Cache Information:
2/4-MB Pages:
Data TLB: associativity L2 off #entries 0
Instruction TLB: associativity L2 off #entries 0
4-KB Pages:
Data TLB: associativity Direct mapped #entries 0
Instruction TLB: associativity Direct mapped #entries 0
size 2 KB associativity L2 off lines per tag 129 line size 64
Advanced Power Management Feature Flags
Has temperature sensing diode
Maximum linear address: 32; maximum phys address 34
Bye bye.
Reply 9 of 49, by swaaye
Rank Moderator
Moderator
Athlon XP was actually the first AMD chip with full SSE support and there are none with SSE2. The only major disadvantage to this to my knowledge is with H.264/VC-1 hardware decode requiring SSE2. If you want that on your "retro" rig, then go Athlon 64 or P4.
Reply 10 of 49, by cdoublejj
Well some time ago i had put windows 7 on a barton core machine paired with an nivida 6200 and not only did it run aero it was running flash games at the same time and smoothly something that would normally murder a CPU form that era. So i guess it looks like the later P4s have the upper hand.
As said they are great clockers so i'm sure with tweaking it would be just fine even stock clocks it's still fairly snappy.
I'm still curious as to what the copper shims were used for, i was thinking to help prevent cracking of the die?
Reply 11 of 49, by elfuego
I heard that rumor too - but I never cracked any dies so far and I changed a whole lot of them so I never used them myself. Never really saw need for that. Also, the rumor that it helps cooling down smells like a blatant lie to me. Maybe I'm wrong though... I guess it would be worth finding out, but - meh... 😖
Reply 12 of 49, by cdoublejj
I don't see how it could cool either.I could see how it could possibly keep from cracking dies. My buddy was tech at the shop i work at long before me told me about they saw all kinds of cracked dies.
Reply 13 of 49, by luckybob
as a member of the overclocking "scene". I never once saw anyone of my peers crack a core. I've seen many get chipped, but they were doing things you shouldn't be doing. That said, anyone putting a big heatsink on a board almost always used a cpu shim. For $2. Nobody risked it.
ebay:
http://www.ebay.com/itm/280573921428?ssPageNa … 984.m1423.l2649
Reply 14 of 49, by elfuego
luckybob wrote:
as a member of the overclocking "scene". I never once saw anyone of my peers crack a core. I've seen many get chipped, but the […]
ebay:
If Thermaltake Big Typhoon that I use qualifies as such, then I dare to digress 😀 Never used those, and I've used a lot of really big heatsinks 😀
Reply 15 of 49, by SquallStrife
Pfft. It's not a real Socket A cooler unless it makes your ears bleed.
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 17 of 49, by CapnCrunch53
That looks exactly like the cooler I have, paired with a monster fan. Seems like Thermaltake sold that design a couple of different ways.
Reply 18 of 49, by NamelessPlayer
What in the...that Thermaltake HSF pic looks like a Golden Orb, except it's significantly taller to accommodate the fan, and the lower part's blue.
Just how many variants of that Golden Orb design did they produce?
My Athlon XP 3200+ certainly deserves a better HSF than the stock one...just can't decide on what to get.
Reply 19 of 49, by SquallStrife
That one's a Dragon Orb actually. The xyz Orb range was pretty big. 😀
