First post, by vetz
I've finally gotten my 486 system with motherboard Asus VL/I-486SV2GX4 Rev 2.0 and a 486 DX4 100. No picture or POST when I press the power button. Not a single beep from the PC speaker.
From the information I find it does not support EDO SIMM RAM which the seller sold with the machine and said would work (machine was ribbed of some parts from when it was running). These are the chips I've got atm: http://doc.chipfind.ru/ti/tm248gbk32f.htm . Can anyone confirm that these won't work in my system?
So I guess I need FPM SIMM ram. Are there any requirements on the NS I need? The specifications found here: http://www.elhvb.com/mobokive/archive/asus/48 … /vi-486sv2g.txt says 80ns. Can I use 60 or 70ns if I find that?
Reply 1 of 9, by sliderider
This says you can't use EDO RAM with that motherboard
https://groups.google.com/forum/?fromgroups=# … sus/nD4-BVixD64
The link is too long to click so you'll have to copy and paste it.
Reply 4 of 9, by Anonymous Coward
Hasn't this one already been discussed to death? If the motherboard manual (or sometimes chipset) explicitly says you can use EDO, then you can use it. Otherwise, it's a bad idea. Some boards that don't support it have no problems, others slowly exhibit signs of instability, while others still won't boot up at all. Be warned that even chipsets that officially support EDO sometimes only do so in certain revisions, so you can't make sweeping generalizations like "SiS496 and UM8881F work with EDO".
Additionally there is no performance benefit whatsoever for using EDO RAM in a 486 board. The only way it is a useful feature is if FPM DRAM is not available.
Reply 5 of 9, by SquallStrife
Anonymous is right, I don't see why you'd use EDO on anything lower than a Pentium. I think Intel's first EDO chipset was the 430FX?
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
Reply 6 of 9, by vetz
Been in talks with the seller, he admits that he didn't think of the FPM and EDO RAM issue. Also he doesn't have any other SIMMS laying around, so I guess I gotta buy some FPM DRAM on Ebay.
Reply 7 of 9, by feipoa
Anonymous Coward pretty much summed up the 486 EDO RAM story. My only small bit to add is that sometimes certain EDO/FPM RAM sticks work, while others do not. This symptom becomes more pronounced when you start working with fast cache/RAM timings and a bus at 40 MHz+. It is always a good idea to have pairs of different FPM and EDO RAM around for testing purposes.
On a slightly modified note, I wonder what the lifetime of the SIMM slots are? I figure if they have had RAM in and out often enough, the spring effect of the contact might get worn. It would only take one contact point to be flakey. On a few boards, I've noticed that RAM didn't work in the first SIMM, but would work fine in SIMM 3, for example.
Reply 8 of 9, by RacoonRider
If you were from my city or country, I would give you several 8MB FPM sticks for free. Unfortunately, international posting here in Russia is not only red tape, it ruins such items most of the time. That's why ebay refused to work in Russia for so long.
Reply 9 of 9, by vetz
Received the 32MB FPM memory from the Ebay seller today and the system booted straight up. Installed Windows 98 and good to go. Just need get the rest setup now 😀
