First post, by vetz
As the title reads, trying to get the power LED on the case working. Problem is that there is no power led connector on the motherboard. The cable is a typical green and white 2 pin cable. I've tried connecting it to a 5V fan to molex adapter, but that didn't work. Any ideas?
Another question I have is the 5 pin keylock. The case cable is only two pin, so do anyone know which pins to connect it to?
This is an AT 486 system.
Reply 1 of 12, by Markk
The Keylock connector is also for the power led. The power led should be a 3 pin connector with a missing pin on the middle. The first two pins on the board I think are for the keylock, so pins 3 and 5 should work for the led. Check the polarity. If it doesn't work one way, try the other.
Reply 2 of 12, by numeriK
What motherboard are you trying to plug everything into? If we can get a picture of the board, or a schematic, I'm sure we can point ya in the right direction on what-to-plug-into-where.
8433UUD v2 | AMD 5x86 @ 180MHz (60MHz x 3, 30MHz PCI) | 64MB EDO | TNT 16MB PCI | SB AWE64 ISA | Win98SE
Reply 4 of 12, by vetz
Mobo is: Asus VL/I-486SV2GX4 Rev 2.0. Doesn't say anything on the schematics or user manual found online where to connect the power led (from what I've found)
I've found this while browsing. http://www.pcguide.com/ref/mbsys/mobo/comp_Connectors.htm . The keylock now works with using pins 4 and 5, but since I don't have the key to the case and it is in the "locked" position there is no point using it. Tried connecting the power led to 1 and 3 and then swapping them the other way, but to no luck. I'll try 3 and 5 as well, just to make sure.
The molex trick I read while googling for this problem, but that may have been for an 3rd party LED. So it might have gotten burned out? I didn't see anything when I connected it (like going extremely bright and then dieing). Thought they were supposed to run on 5V.
Reply 5 of 12, by Markk
If you know how to remove the cables from the connector(as they should use 2 pin connectors instead of 3 like the power led) you can use either the turbo or hdd led to test and see if it's working when connected to those pins. If it does, then probably your original power led is burned.
edit: I had a motherboard and an AT Power supply handy over here, and started it in order to measure the power led voltage using my multimeter. It reads 5.05v while the 5v molex cable show 5.07v, so I guess it's not so likely to have burned the led by connecting it there.
Reply 6 of 12, by Old Thrashbarg
You're forgetting about current. If you feed an LED 5V direct from a molex without a current limiting resistor, you'll fry it in pretty short order. The LED headers on a motherboard, OTOH, usually have such a resistor built into the circuit.
Reply 7 of 12, by JaNoZ
Usualy, lets hope so, they are for sure.
5v on the led will burn it for sure if not explode or short out on your power supply. Bad idea.
Reply 8 of 12, by Markk
Yeap, you're right. First I thought that it would be ok, as I have seen some of those speed displays that feed directly from the molex, and the turbo led goes on them instead of the motheboard. But after a second thought, it's obvious that some sort of limiting resistor as you mentioned has to be on the display's small board.
Anyway, I thought I should test this just for fun. I connected a green led on the molex 5v rail, and it lights up, but it's color changes to yellow... I had it powered like that twice, and about 7-8 seconds each time. It didn't burn but it's clear that it's not meant to be used like that. Sorry guys, my mistake.
Reply 9 of 12, by vetz
Looks like I've burned the LED. I connected the turbo led cable to the power led pins 1 and 3 while at the same time connecting the power led cable to the turbo led. No light in the power led, while the turbo led stayed on even if I pressed the turbo button on and off.
Are these kinds of diodes hard to replace? I guess it will be hard to find a similar one so that the power led doesn't shine much brighter than the others.
Reply 10 of 12, by 133MHz
They are cheap and easy to find. Any decent electronics store near you should carry a wide selection of colors, shapes and intensities. They usually have a working display or let you test them individually so you can pick one that suits your fancy.
http://133FSB.wordpress.com
Reply 12 of 12, by SquallStrife
Farnell / element14 and RS Components are good online options for components.
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
