First post, by kataniel
I currently have the option to get a Matrox Millenium with 4MB.
I can choose between the one with the MGA 2064W-R3 and the one with IS Storm R2 - both with 4 MB of WRAM.
Which one should I take? The system is a P233MMX on a FIC 2010+. Windows 3.11 runs at 1280x1024. Additionally, I'd like to play Quake (*only* software rendering (no GL) because of the "dirty" look) and some older DOS games.
I currently have a Mystique 220 with 4 MB installed.
Is it worth to switch to one of the Milleniums concerning speed and image quality (quality especially for windows)?
Dell Optiplex GL5100 | Pentium 100 | S3 Trio64V+ 2MB onboard | 64MB EDO | WDAC2850 | FX810 | OPTi 82C929 + NEC XR385
Dell Optiplex 466LE | am486 DX5 133 | CL-GD5429 1MB onboard | 8MB FPM | WDAC2540 | FX400 | HOT-235 + DB50XG
Reply 1 of 8, by NitroX infinity
Stick with the Mystique 220. It's newer, faster and supports DirectX 3 (Millennium supports DirectX 2).
NitroX infinity's 3D Accelerators Arena | Yamaha RPA YGV611 & RPA2 YGV612 Info
Reply 2 of 8, by Putas
Yeah, SGRAM of any Mystique will run at significantly higher frequency then Millennium's WRAM, so I wouldn't expect any better performance. If you have older Millennium it can even have slower dac then Mystique 220.
Reply 3 of 8, by vetz
I own both these cards. When it comes to 2D they are very similar in practice, as the Mystique is in many ways a rebranded Millennium II with gaming capabilities (MSI, D3D). The Mystique is probably a tad quicker in 2D. All in all you can do more with your Mystique card than your Millennium. For VGA output quality both these cards are solid.
Reply 5 of 8, by swaaye
Rank Moderator
Moderator
I think Millennium 2 is faster than Mystique 220 at 2D if you are using a high resolution like 1600x1200. In D3D they seem identical, even displaying the same bugs.
I avoid Matrox cards prior to G200 though because of audio and image corruption problems I have had using them.
http://web.textfiles.com/computers/vgakills.txt
Reply 6 of 8, by NitroX infinity
Uhm, guys, he's comparing a first generation Millennium to a second generation Mystique. The Mystique 220 is definately better than a first generation Millennium.
Reply 7 of 8, by swaaye
Rank Moderator
Moderator
I was responding to chat about Mystique vs the other cards. I've seen benchmarks showing the WRAM cards doing comparatively better with 2D at 1600x1200.
Matrox is so overrated that it's silliness anyway. For gaming+2D there are much better options like a Voodoo3 or almost any NV card (just have to find one that's not blurry).
Reply 8 of 8, by kataniel
Thanks guys for all your comments.
That helps me to save some money. I'll stick with my Mystique.
As an alternative, I have a VirgeDX with 4MB. Perhaps I'll have some time around christmas to compare it to the mystique in the P233 MMX system.
@swaaye
Yes, there are better cards, but for the P233MMX I was looking for a contemporary one. A Voodoo3 or any NV card is at least three years too "new" 😀
