First post, by Kahenraz
- Oldbie
From what I understand, I have to run the "au30dos.com" utility which reads information from the accompanying .ini file. I also found that for this utility to work, the drivers must be installed in Windows 98 and the utility run from C:\Windows (where it is installed). All of that is fine and it says it's running ok and mapping to p220 d1 i7.
DOS games work just fine when run from within Windows. However, if I attempt to run then in pure DOS with au30dos.com (with or without emm386), I always get crackle-pop-static when attempting to play digital samples. Midi works fine.
Does anyone have any experience with this?
Also, what I want is good sound blaster support from a PCI sound card IDEALLY with a WaveBlaster port. I will consider alternatives if anyone can recommend one.
