The Ultimate 686 Benchmark Comparison
Reply 120 of 139, by zapbuzz
I hate to be a pain but I am compelled to submit this comment.
It doesn't matter if its 286, 386, 486,586 or 686 they are all graded to their best frequencies at the factory.
a 1.1GHz/100MHz pentium III coppermine is the factories best lithography production for its socket at that frequency. The slower ones are graded to the limits
of a less perfect copy that simply cannot run at higher frequencies due to imperfections.
Thus the true potential of all socket technologies would be best observed by utilizing each sockets fastest production processor as a measure of confidence in findings of their true potential as a member of generation for form factor comparison.
To confirm my findings would be to compare a models range from slowest to highest you will find slower ones draw a whopping amount of energy for its speed as the fastest ones would need but fast one underclocked say a 1ghz pentium III underclocked to 866mhz to compete with a standard 866mhz pentium III the 1ghz still computes more efficiently and uses less power because it is a better silicon copy of the pentium III processor. The example i have provided i have already proved to myself and today I have a core duo pentium running since 2006 simply under clocking it and I hear nothing about them anymore. It runs at 22oC in 64bit mode and I HATE LINUX OK so thanks for reading and have a nice day. oh btw tulatin cpu's destroy coppermine machines so don't do it if the manufacturer didn't program its bios initially.
Reply 121 of 139, by gdjacobs
zapbuzz wrote on 2020-05-10, 20:17:
I hate to be a pain but I am compelled to submit this comment. It doesn't matter if its 286, 386, 486,586 or 686 they are all gr […]
a 1.1GHz/100MHz pentium III coppermine is the factories best lithography production for its socket. The slower ones are graded to the limits
Market segmentation isn't the same as production binning. If Intel needs an order of inexpensive CPUs filled but all they have is dies that qualify for use in a more expensive product, they'll ship using the more expensive dies rather than not ship at all.
This can happen as mature designs and processes begin really yielding well. A Coppermine 1.1 ghz will definitely be from the highest grade bin when tested for speed, but there's a significant chance that a Coppermine 933 mhz, for instance, could perform equivalently well were it not multi locked. Also, stability at frequency is not always related to power dissipation.
Reply 122 of 139, by kool kitty89
I think a comparison focusing on maxing out a given motherboard socket/bus architecture (or even chipset range/generation) would be more the sort of topic that would fill some of the qualities listed in zapbuzz's post.
As it is, it's often the bus design and/or chipset limitations that skews some of the performance comparisons here, and some of those are a compromise, too (you might be limited to choosing between faster DRAM performance vs board level cache speed vs cache vs PCI and other I/O bus performance, and then tolerance to overclocking on top of that). Some of those are motherboard-model specific limitations, some are actual chipset ones, and some are just luck of the draw on an individual board/chipset used. (especially as far as running things out of spec)
The Cyrix Media GX gets a particularly raw deal as far as limited motherboard chipsets go and lack of board-level cache support.
To be fair there, you'd probably need to go for a comparison disabling all external cache: in which case you'd also tend to get more emphasis on CPU and chipset DRAM access/throughput performance as well as the size and performance of on-chip cache and FSB overclockability and/or tight DRAM timing tolerances. (you might also get some weird cases there where otherwise slow chipsets have relatively good performance with the board level cache disabled along with DRAM timing tweaks: this seems to be the case with the OPTi 495SX 386/486 chipset, though it doesn't show much when 1x multiplier 486 or 386/486DLC CPUs are installed and I have no DRX-2 CPUs to compare)
I think the point of this thread's benchmarking efforts was mostly for comparison purposes between mid/late 90s era x86 CPUs (ie from late gen 486 socket CPUs to early gen Coppermine and Athlon CPUs).
One specific part of the U686BC here was comparative clock for clock performance.
As far as pushing a given socket/FSB architecture as far as it can go (or perhaps x86+IA32+extended instruction set spec range), that's usually going to be down to overclocking to parts of the chipset along with cache and/or DRAM as well as the CPU. And in that case you could end up favoring somewhat lower performance chipset and/or CPU per clock in favor of ones that tolerate overclocking the most.
To that end, the issue of both chip binning and market segmentation also come into play. And in addition to what was already said above, there's also some manufacturers who tend to be more conservative with their ratings than others and thus end up with parts that more often run fine when set further out of their specified tolerances than typical. (with average or less conservative ratings, you'll still usually have some extra room to push things if you keep temps below the typical 70C spec among other things)
On top of that, you have official speed and voltage ratings that were sometimes limited to practical power consumption and cooling limitations (or expectations) of the day. On the power end, you could have that limit on the power supply or also board-level voltage regulators (though for old, strictly 5V boards you don't normally have those ... and then you have some Socket 4 pentium boards with voltage regulators boosting things to 5.25 or 5.27 volts)
You get into overvolting in the 486 era (though I suppose there may have been some 5.5-6V PSU/board mods for older 5V systems, too) and then more of that introduced with Socket 7 or at least the ability to tweak voltages on many boards, sometimes just to officially used settings, sometimes specifically for tweaking.
With earlier Socket 5 (and some early socket 7) boards, you didn't have much flexibility there with just the 3.3 or 3.4 or 3.52V core and I/O spec. There may be some boards that had 3.6-4.0V settings, but I haven't seen any of those myself. OTOH, voltage regulator mods often aren't that complicated and were probably done for overclocking purposes back then. (and I think most of the chip processes down to 350 nm were fairly 4V tolerant with sufficient cooling, but that could vary by manufacturer and might also be limited by external surface-mounted components like resistors onboard the CPU package)
I believe Cyrix and Nexgen both used similar IBM manufacturing processes at one point, though I think Cyrix got in earlier with the .65 micron process and NexGen with .5 micron (but maybe they also worked with .65 micron parts) and Cyrix officially rated parts up to 3.7V (with some 5x86 models) and NexGen consistently used 4.0V ratings on their Nx586, including the later .35 micron parts from what I've read.
However, Cyrix never went beyond the 3.52V rating for the 6x86 and IBM tended towards a more conservative 3.3V with the 5x86 and 6x86 (though I think I've seen some 3.4 or 3.5V IBM 6x86 parts). Cyrix and IBM also used the same .35 micron process for both late production single-rail 3.3-3.52V rated parts and 2.8V 6x86L (and some 2.5V mobile versions) and while it's possible the SMDs on some 6x86Ls are out of spec at 3.5V, they appear to tolerate 3.5V for extended periods in my experience. (similar to overvolting Intel P55C parts, except there's some late production .28 micron Intel P55Cs that might be more vulnerable)
I'm pretty sure many of Cyrix's ratings were limited my power consumption and heat dissipation issues as well as willingness of motherboard manufacturers to officially support higher power dissipations at the time, but the few Socket 7 and Super 7 boards I've tried tend to overclock 6x86Ls quite well and all my PR-200s will work in Windows 98 at 3x66 or 3x68 MHz at 3.3 to 3.5V. (with late SS7 or Socket 370 or 462 era heatsinks+fans)
That might also be a market segmentation thing, since the M2 core (6x86MX) may have been on the market by the time the 6x86L hit reasonable yields at boosted voltages, but then they also stuck with 2.7 to 2.9V with the 6x86MX when AMD resorted to the 3.2V K6-233. And as far as I can tell, the early 6x86MX parts used the same (or similar) .35 micron process as the 6x86L though was also a larger chip than the 6x86L or .35 micron K6, but I'd think a 3.2 or 3.3V M2 at 3x66 would've been in the ballpark of what AMD was doing and avoided needing boards (and RAM) with 75 or 83 MHz support at the expense of needing sufficient power consumption/supply tolerances.
I actually haven't tried overvolting and overclocking early Cyrix/IBM M2s, so maybe they don't even do as well as the M1 there due to the design changes/tweaks or maybe just the cache sort of like AMD's troubles with the K6-III.
Except in that case they missed an opportunity at selling factory overclocked M1s to the 1996/1997 gaming market, for Tomb Raider or Quake-like FPU-requisite games and just really demanding ALU-only games, especially with SVGA res modes. That and maybe modifying the M2 core to support decoupled CPU and FPU clock multipliers. (the FPU supposedly didn't change at all and certainly doesn't seem to have trouble at 200+ MHz in the M1, plus made up an increasingly smaller portion of the CPU die area and power/heat dissipation from 486/5x86 to M1 to M2)
What's weirder is that Cyrix and IBM subsequently bumped the 2.7 or 2.8V rating of early 6x86MX parts to a consistent 2.9V for the Cyrix MII and later gen IBM 6x86MX parts and did so both for late production .35 micron and all .25 micron parts (except low voltage mobile and embedded rated ones) in stark contrast to AMD's 2.2 to 2.4V rated .25 micron K6/2/3 and Intel's 2.0V rated .250 nm Pentium II, Celeron, PIII. But again, that doesn't automatically mean AMD and Intel parts of that sort can run safely at 2.9V as the processes might differ in other ways or simply the SMDs used external to the die don't tolerate that or might tolerate 2.8V or 2.9V with generous cooling but might slowly die and might instantly die a bit higher than that. (and with PIIs and Katmai IIIs you have the external cache further complicating potential failure modes)
National Semiconductor 250 nm M2 cores were also 2.9V rated, but then you have the 2.2V rated 180 nm parts that made up the end of the line for Cyrix MII production. (which is very high voltage for 180 nm parts, and I'm not sure if there's significant differences in construction than with AMD or Intel 180 nm parts, aside from AMD's copper interconnect, or if the relatively modest clock speeds and power dissipation just made that sort of voltage rating attractive for yield management or if those Cyrix NS parts might actually have more headroom for overvoltage than AMD or Intel parts)
So, in any case you might have some success running a Mendocino Celeron on a 2.8V Slot-1 board and potentially max out a 440FX or LX based system or potentially a BX board with .35 micron PII support, but you'd be better off with an overclocking-specific board that supported 2.2-2.6 volts or so. (though it seems like a lot of Slot 1 and Socket 370 boards are 2.0V only or 2.0 and 2.8V only where voltage tweaking and overclocking support is a lot more common in Socket 370 Coppermine era boards, though it might be that Intel chipset boards more often lack voltage tweaking)
Unlike Super Socket 7, it's also fairly uncommon to have Socket 370 boards that support all Socket 370 CPUs, especially ones that support both Mendocino and Coppermine chips. (that seems a good deal rarer than Tualatin support or boards with unofficial Tualatin compatibility for that matter)
To that end, you can also overvolt Coppermine PIIIs and Celerons quite a bit and push some well beyond the 1.1 GHz limit, and with the much lower power dissipation at stock voltage and same clock rates as competing Athlon and Duron chips you also have some headroom working with CPU cooling solutions from the time, especially given the cross compatibility of Socket 370 and 462 for heatsink mounting hardware. (of course, you want to be careful with power supply limits too and especially avoid stressing a cheap or otherwise non-fail-safe PSU that could take the board with it if it dies)
Bear in mind 5V vs 12V rail demands given emphasis on the 12V rail became common in the P4 era but usually the 5V supply lines are the stressed ones in S370 up to early or even mid generation Athlon XP and MP boards. (12V demanding boards usually have an auxiliary 12V power connector, the typical square 2x2 pin one or sometimes a 1x4-pin HDD style MOLEX connector: the latter was at least used on later revisions of some Athlon MP workstation/server boards that had originally been 20-pin ATX only)
I had my old Celeron 1000 running at 1250 MHz without apparent problems around 9 years ago, but didn't bother stress testing that as I had a Tualatin Pentium IIIs 1.4 I stuck in that same board shortly after for a fast DOS+Win9x gaming build and to play around with overclocking that. (it did fine at 150 MHz FSB 1575 MHz, but Tualatin chips are known for going to 1.6 GHz or so without excessive voltage)
I actually got several cheap Celeron 1000s and 1100s a while ago I want to try to test the limits of at some point. (I may also have some 100 MHz Coppermine PIII 1000s, but I'm not sure ... I may have avoided that due to the price/availability, though I did also get several Tualatin celerons of various speeds to try out: other than my or my Brother's original 1300 Celeron that I'd had running at 1625 MHz for a while, pulled out of storage around the same time as that Celeron 1000)
Though on the K6 family:
I can say from experience on .25 micron AMD K6 or at least K6-2 era parts seem to die instantly at 3.5V or at least near that, potentially board/VRM dependent ... not a slow death or overheating related one either, but instant pop-dead: both a K6-III 400 I accidentally set at 3.5V and then a K6-II 300 I sacrificed to testing after that to confirm what I'd done: it tolerated up to the 3.4V setting without immediate problem, but failed to post at 3.5V and was completely dead after that.
I'll probably delid those AMD CPUs at some point to examine the SMDs on there in case a surface mount capacitor or resistor popped or something. (I'm not actually sure what the SMDs are on K6s, though I think some are used for jumper-selecting certain features, especially with K6-III dies: I've actually wondered if the L2 cache in there can be re-enabled on certain K6-2/400 and 450s that use the same die, but I think at least some of those may be coupling capacitors)
I'm not sure the 180 nm K6 II/III+ are as sensitive, relatively speaking (ie if they tolerate 2.6 or maybe 2.8V without instantly dying), but don't want to sacrifice one of those to find out. Or actually, if a linear scale of voltage has anything to do with it, I guess 2.9 or 3.0V would actually be closer , but I'm not sure that's relevant either. (also later socket 7 boards, or at least my P5A-B has some sort of current limiting or other safety feature that outright refuses to fully power on the board at certain settings: it may have actually prevented me from discovering the 3.5V vulnerability years earlier as it tends to refuse to power on or sends error beeps with K6-2s set much above 2.6V so even momentary POST testing wasn't possible there: though it does tolerate 2.6V and 6x100 as is a more typical maxed out K6-2 550 overclocking configuration)
Or maybe the BIOS has an automatic shut-off safety feature if it detects a K6-2 or late K6 stepping along with certain voltage jumpers.
I also don't really want to risk killing any of my Cyrix or IBM .25 micron CPUs to see if they're as sensitive as AMD ones, even though those are 2.9V rated parts and probably have more generous surface mounted stuff on them if not other aspects. (I may have already run them at 3.5V in the past but didn't document it: I know I went up to at least 3.3V when overclocking my first MII-366 and it's still kicking, though 3.3 didn't do that much in the first place and it already ran OK at 300 MHz at the stock 2.9V and was never very happy at 330: though since discovered it seems to run fine at 2.2V at the stock 250 MHz)
Reply 123 of 139, by BSA Starfire
One motherboard I do know that supports both Mendocino and coppermine core natively is the ASUS CUSL2, it uses the intel 815 chipset. I have one setup currently with a 466MHz mendocino celeron, voodoo banshee and 256 MB RAM. Really decent little machine. I've used coppermine Celerons & PIII's in this machine, only down side is it does not run VIA C3 CPU's.
Reply 124 of 139, by zapbuzz
kool kitty89 wrote on 2020-05-14, 07:31:
I think a comparison focusing on maxing out a given motherboard socket/bus architecture (or even chipset range/generation) would […]
Thats a post worthy of a sticky thankyou kool kitty89
Reply 125 of 139, by kool kitty89
Now someone goes that route with a maxed-out motherboard thread, I'd think it'd be OK to include overclocking and running CPUs not officially supported by the board within reason. (which would probably mean: scenarios where neither the board nor CPU are stressed to the point of likely failure)
So Pentium MMX or .35 micron 6x86s or 6x86MXs or K6s should be OK in single-rail 3.3-3.5V Socket 5/7 boards for example, provided you don't overload the onboard voltage regulators. (the external 3.3V line could also come into play on boards using the ATX power socket) And while already near their limits, 3.2V K6-233 often run fine at 250 MHz (3x83 MHz, which some single-rail boards support) and may do OK at 3.5x75 though in other cases 3x75 might be a happy compromise. (they also do OK at 2.5x100, but that's SS7 and maxing out the CPU and not the board: it might do 3x95 but mine would not do 3x100 at least, unlike a couple 233 MHz rated Cyrix MII 300s I have)
Oddly enough, my P5A-B came with a K6-233 back when I got it somewhere around 2010.
There's probably some 3.3/3.4/3.6/3.7/4.0 rated 486 socket CPUs that tolerate 5V well enough for long-term use as well (provided with sufficient power supply and cooling) but I'm not if there's any definitely 'safe' examples there aside from cases where the same processes and packaging was used for both 5V and lower voltage ratings based on yield.
Sometimes specifically graded to support low voltage operation up to a lower max clock speed: this was definitely the case with some later model 68HC000s and 68EC000s and I think some models of '020, '030, and '040; Hitachi's SuperH RISC processors had some 3.3 and 5V specs for the same CPU models, and I think AMD's 29000 family had some of those, too. (I don't remember seeing this specifically mentioned in any x86 CPU datasheets I've seen, though ... or maybe in some of NEC's embedded offerings or maybe some 80C186 models)
I can say I've put over 100 hours of operating time into one particular ST-486DX4 100 at 3x40 MHz in a 5V board without apparent detriment (that includes quite a bit of X-Wing and Tie Fighter play time), but that's hardly long-term but still well beyond the sort of case where a CPU works just long enough to run some benchmarks and such for a few minutes or a few hours and then dies.
Feipoa mentioned killing at least one Cyrix 5x86-100 at 150 MHz overvolted (I think 4V in this case, but I'm not sure) but that was a PQFP model (poorer thermal conductivity) and I'm not sure what he used for cooling, so it's not clear how much damage was due to voltage and how much was overheating. (though both combined could potentially stress limits that either alone would not and high voltage + high clock speed + insufficient cooling can lead to thermal runaway)
AMD 5x86s have more examples of dying at 5V, especially overclocked, but (as said in a previous post) those are .35 micron vs .65 micron of IBM-Cyrix 5x86s. I don't believe AMD's .5 micron DX4-100s and 120s are as fragile but haven't read anecdotes either way. (if nothing else they have larger dies that distribute the heat over a larger area vs the tiny 43 mm^2 .35 micron DX4 and DX5 chips)
Reply 126 of 139, by kool kitty89
You could also look at things limited to the officially specified tolerances. In which case, I believe the Cyrix/ST 486DX2-80 is the fastest 5V rated 486-socket compatible CPU that doesn't require a voltage regulator adapter or integrated PCB mounted one. (Pentium Overdrive included, except that's also not suitable for socket-1 style PGA-168 sockets without the additional Socket 2 or 3 pinout vs Evergreen style voltage-regulated upgrade AMD x5 or Cyrix 5x86 chips)
That and similarly overclocking without voltage boosting out of spec.The AMD x5 does 4x40 MHz pretty often at the stock 3.45V or a modest tweak to 3.5 or 3.6V depending what was available on the board. Cyrix had DX2s specifically citing a range up to 4.0V, etc.
Also, even if you wanted to overvolt AMD's DX2-80 chips (and presumably similar vintage 3V DX2-66s) you could run into the problem that the default (unjumpered, floating mul select lines) multiplier setting is actually 3x and not 2x and an overclock of that level might not be suitable (be it stability, heat, or power demands). Best case there would be overclocking an older 5V AMD DX2-66. (though 3x25 could be a possibility too and could perform decently with boards with low DRAM and cache wait states and/or good use of burst/page mode operation, that or if a board used a discrete crystal oscillator, you could use a non-standard speed like 27x3)
Most 5V only boards also probably don't explicitly specify DX2-80 models of any kind (I think they typically had DX-50, DX2-50, and DX2-66 as the fastest models listed)
I suppose more on topic for the 686 benchmark comparison there would again be the AMD K6-233 mated to a Socket 5 board. With 3.3V still being within the official margin of that spec (and there appear to be some OEM-specific models with 3.3V explicitly printed on them, too)
Say you had a nice, fast 430HX board with single rail voltage and 66 MHz bus speed restriction: a K6-233 could be a pretty decent fit there.
Reply 127 of 139, by gonzo
I am very happy to see this benchmark-site! 😀 Can someone tell me please, how to reach a correctly score in 3D Mark 99 MAX using Cyrix-6x86-L-CPUs (that means not MX-versions)? At the first page, feipoa lists some L-Versions for testing, but (unfortunately) I'm not able to find their 3D-Mark-99-scores anywhere...I tried some L-Versions on different socket-7-Boards -> they work perfectly with 3D Mark 99 max, BUT the scores are simply too low (somewhere in between 15 and 20 points), similar to 486-CPUs. I assume, the problem is the missing pentium-ability of the 6x86-L. Can this score-problem be solved? 😀 Thanks and greetings.
Reply 128 of 139, by feipoa
gonzo wrote on 2021-01-03, 14:06:
I am very happy to see this benchmark-site! :-) Can someone tell me please, how to reach a correctly score in 3D Mark 99 MAX using Cyrix-6x86-L-CPUs (that means not MX-versions)? At the first page, feipoa lists some L-Versions for testing, but (unfortunately) I'm not able to find their 3D-Mark-99-scores anywhere...I tried some L-Versions on different socket-7-Boards -> they work perfectly with 3D Mark 99 max, BUT the scores are simply too low (somewhere in between 15 and 20 points), similar to 486-CPUs. I assume, the problem is the missing pentium-ability of the 6x86-L. Can this score-problem be solved? :-) Thanks and greetings.
I also ran into this issue and I had tried several graphic card driver versions, but the result was the same - the scores were abnormally low. At first I thought it was due to missing MMX instructions, but I don't think the original Pentium had this issue, so that couldn't be the reason. These Cyrix CPus are missing something to cause this result, but I'm not sure what.
Reply 129 of 139, by gonzo
feipoa wrote on 2021-01-13, 07:23:
I think, the 6x86-L-CPU itself is maybe not the problem (because the problem occurs for all 486-CPUs, too). So the problem can only be caused by something missing from a Pentium-CPU (compared to the Pentium) . I am pretty sure, it is not a VGA-problem. 3DMark 99 (MAX or not) does not require MMX, so this can not be the problem, too. On the other hand, 3D Mark 2000 requires MMX - so its tests simply do not start with the 6x86-L.
At this site (https://www.deinmeister.de/e_cy6x86cr.htm) they can be found two possible "pentium-compatible" software-solutions made for the Cx-6x86L. Unfortunately they do not work for me (used directly under WinME, without installed DOS in advance / in the background). The first one (The CPUID instruction) just seems to do nothing - nothing is visible in the DOS-mode-window unter ME (no message, nothing happens, etc.) . The second one (The Time-Stamp-Counter), tested with a HEX-editor and some 99MAX-DLLs "on-good-luck", was without success, too. Any other ideas? 😀
Reply 130 of 139, by zapbuzz
considering how rare old cpu's are i could never overclock unless it was to stablize clock + power rails and usually thats PSU cause instead (re capping is tedious)
Reply 131 of 139, by Horun
zapbuzz wrote on 2021-04-19, 13:10:
I agree ! Back in the day (late 90's thru 2000's) did a fair share of OC but today am not going to risk cpu+motherboard of that same era just to see how far it can be pushed.
I do enjoy reading about those that have the balls to OC old parts knowing the risks but think if I stumble on a member who has been OC and then the board dies and they ask for help... will remind them that it is unwise 😀
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
Reply 132 of 139, by BitWrangler
So I saw this the other day and began wondering about it...
The last Cyrix-badged microprocessor was the Cyrix MII-433GP which ran at 300 MHz (100 × 3) and performed faster than an AMD K6/2-300 on FPU calculations (as benched with Dr. Hardware).
from https://en.wikipedia.org/wiki/Cyrix#Merger_wi … l_Semiconductor
So I would assume that that is a 2.2V CPU on 180nm, and I don't recall any earth shattering results from the lower speed 2.2/180 MII that we've seen more of. It is merely an artifact of how Dr Hardware does FPU benches, or do you think the K6/2-300 was just crippled on a 66 bus (as was officially supported at release)
Also curious about any performance difference between CXT K6-2 and prior cores which I don't really see addressed.
2017: Basement full of ancient PC stuff, starting to go through it. 2021: Still starting, heh, many setbacks. So what's this BitWrangler guy's deal ??? >>> Taming the pile, specs to target?
Reply 133 of 139, by lukas12p
From my notes, Quake1 benchmark, Matrox PCI:
Cyrix MII333GP @3,5*83=250 MHz ...45,8 fps
AMD K6-2 400 @3*66=200 MHz ...42,3 fps
AMD K6 200 @3*66=200 MHz ...40,5 fps
AMD K6 200 @2,5*100=250 MHz ...52,9 fps
Cyrix GXm 9*37,5=333 MHz ...35,5 fps
Reply 134 of 139, by feipoa
Is that 37.5 MHz option on your GXm board undocumented? Was there not a 10x multiplier setting on your board to run it at 10x33.3 ? Can you remind me what board you are using? Also, l what CPU are you using? There was a very rare GXm from Cyrix that is marked for 300 MHz, but the 2.9 V, I suspect, caused issues on my board at 300 MHz. I find the GX1 chips a lot easier to deal with at 300 MHz +, likely due to the 2.1 volts.
Reply 136 of 139, by feipoa
lukas12p wrote on 2021-10-04, 08:12:
Hi
This is P5GX-M motherboard that is offered on ebay. It has documented 30 and 33 MHz FSB only. Processor is typical GXm 266 MHz 2.9 V and it is not stable at 10x33 MHz even with more voltage.
What is the jumper setting for 37.5 MHz ? Normally, J2 is set such that:
30 MHz = 4-6
33 MHz = 2-4
37.5 MHz = ?
Reply 137 of 139, by lukas12p
I don't have this setup connected, but I can see that J2 is set 1-3 and voltage is set at 3 V and multiplier at x8, so I guess this was most stable option (300 MHz) = 32,4 fps in Quake1 with onboard graphic card
Reply 138 of 139, by feipoa
Thanks. I'll look at this the next time I have that system out of the closet. Do you recall how much memory you were using and what the memory timings were set to in the BIOS?
SDRAM CAS latency Time: 2T or 3T
SDRAM Clock Ratio Div By: 3 or 4
At 33 x 9 = 300 MHz, I can get away with the fastest timings, that is 2T and /3, but I must limit the RAM to 64 MB for fully stable operation in Windows. I'd imagine that at 37.5 MHz, you'd have to use 3T and /4.
