First post, by Kurasiu
- Newbie
Hello everyone! Apologies, if this question was already answered, but I searched and searched, and found nothing. I have a question regarding SoundBlaster PCI128 under Windows98's real mode DOS. I recently got my hands on an older PC - and since I really wanted to play some retro games, without any virtual machines/DosBox, I installed the Windows 98 SE (polish version), installed all the Win drivers and added the CD-ROM and mouse support in autoexec/config - everything works well. However all is not well with the sound card. While it works under Windows (used the standard Creative SBPCI128 drivers) it doesn't work at all under DOS.
I'm using the SoundBlaster PCI MAME driver. Did everything, what the instruction told. And, well...during the boot up it says
SB PCI @ port e800, IRQ 5
Output mode is analog
Initalization complete
however when I run any setsound application it simply refuses to work - at autodetect it doesn't detect anything, using autodetect with Blaster parameters results in "SoundBlaster Pro@A220, I5, D5" (which is wrong, sound test fails), and setting the card parameters manually results in either total hangup (DOS) or "exception/illegal operation" error (ran under Windows). Once again - the card works fine, I actually tried using it, before installing Win98, on WinME with Rayman Designer - everything worked at A220,I5,D1 (though yeah, it lacked a real mode DOS)). Any help, even the tiniest, will be much appreciated!
http://pastebin.com/FsLxp81Q - autoexec file contents
http://pastebin.com/LtPXSWZy - config.sys contents
Any ideas? Oh, and I'm terribly sorry for any mistakes, as english is not my first language.
