On the topic of dumpster diving
Im in love with one of my latest finds
I found a Fujitsu Siemens laptop. Old but in good shape from the looks of it.
It turned out to be an Amilo a1630 from 2004. No powerbrick and it used a 4pin! dc-plug so I diddnt have one that fits.
It turned out it needed 20v 8A = 160W 😁 I can understand why they decided they needed a 4 pin plug.
I found an used FSP brick with the correct voltage and plug but only 7.5A for 10 euro.
The correct 20v 8A power brick is 100 - 150 euro new so the FSP brick was pretty much the only choice.
I got the power brick today and it works fine. After reinstalling Windows XP it became quite obvious why the laptop was discarded.
Random crashes and reboots as soon as the CPU was utilized by anything more taxing than Solitaire.
I downloaded speedfan and as I thought the CPU temperature was 60C idle and 90C+ load .
I did some Internet searches and it seemed this laptop was plauged with heat problems even as new.
Perhaps the heat issues are the reason the laptop looks like new and the battery is in perfect condition. It has probably never been used or at least not much 😁
I went on to dismantle the laptop. No dust at all, it was perfectly clean.
Then I removed the CPU heatpipe cooler and it was not very strange that the laptop was overheating.
10 year old cheap cooling paste everywhere exept on the core, and the heatsink was not flat at all 😁
After lapping the heat sink and applying new paste the laptop works perfectly and dosnt even rev the fans much when I run Prime95!
Exept the poor application of cooling paste and the uneven heatsink the Amilo a1630 is very well built.
The specs are pretty crazy for beeing a laptop that soon will be 10 years old.
CPU Athlon 64 3700+ s754 2.4 ghz @ 1.5V
Memory 2*1gb DDR (Installed by me. 2*256 when I found it.)
GPU: Radeon 9700 Mobile
HDD 80gb IDE
DVD-RW
WiFi
5.1 sound with SPDIF!
Screen 15" 1280*800
I will make a thread with pics and benchmarks and stuff for this computer later since it probably will be one of the systems I will use the most.
