First post, by soviet conscript
- Oldbie
here my problem. I have an older 300mhz Pentium II as well as a 450mhz Pentium II but just the chip/pcb whatever its called all caseless. I figured I'd just swap cases and stick the 450mhz into the 300mhz case rather then shell out another $13 - $15 for a 450mhz P2.
question is how do you open these things? I don't see any screws and I don't want to break it.
