Today I would say Flextronics is also a contender for the best PSU OEM title.
Im having an eventful morning 😁. I was going to test some other PSUs with the spare Tualatin system to see if I could find another PSU that would let me overclock as high as the AOpen 350W unit. I tested a Cooltek 500W PSU with two bad caps just to see how it performs, its perhaps also a unit worth recapping. I know the Cooltek unit performed OK even with the two bad caps as I have pulled close to the maximum load from it only weeks ago (before I found the two bad caps and replaced it).
When I powered on the system with the Cooltek unit something exploded after a few seconds. It was a very load bang/pop, the sound of for exaple a solid cap exploding but the system diddnt power off and kept booting Windows until I reached the power switch on the PSU. Well its a spare system no harm done I thought and started investigating. The PSU is still good, or as good as it was from what I can tell as the first thing I did was to test it with a junk P4 motherboard. Then I connected a Fractal Design Newton R2 PSU to the Tualatin system and powered on, everything still works...
Im glad I kept investigating though as I found the issue an hour later, it wasnt related to bad caps in the PSU... When you buy a used system its always good to disassemble the whole system and assemble it again just in case the previous owner has done a poor job. When you fail to do this stuff like this can happen.
This screw is identical to the 6 screws holding the board to the motherboard tray, it has probably been lodged between the motherboard and the motherboard tray since the system was first built...
The system did run with the loose screw in that position but I guess it moved, created a short and something blew because of it. Im thinking it was some sort of small resistor as I have not found it yet. It cant be a very important resistor (or whatever) as I managed to run both 3dmark and HCI memory test without issues before I found the culprit.
Now I will disassemble the system and rebuild it before I do anything else...
Here are two pictures of the Cooltek 500W unit with bad caps. Is this unit worth saving for recapping?
