First post, by Stojke
Can any one suggest a good motherboard with both PCI-X and AGP 4x slot?
My A7M266-D went up in smoke today because #yolo.
I want both on the board because i want to hook up an PCI-X SATA2 controller.
I would prefer if the board had PCI-X all the way down instead of up near AGP - Due to my Voodoo 5 5.5k fans being large.
I would also like to know what is the best AGP 4x motherboard, since dual processor didn't turn out to be as interesting as i thought 🤣
I am pretty sure both AMSN2600DKT3C survived, plus i have one spare.
Reply 1 of 9, by Skyscraper
Do you want the best board that can run a 3.3V AGP 2X card or the best motherboard that can run a AGP 4X 1.6v card?
Most if not all AGP motherboards can handle AGP 4X cards with 1.6V signal voltage.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 3 of 9, by sliderider
Stojke wrote:
Can any one suggest a good motherboard with both PCI-X and AGP 4x slot? My A7M266-D went up in smoke today because #yolo. […]
You'd probably be looking at a server board for something like that. I have a dual 604 board with (IIRC) 1 AGP Pro, 2 PCI-X, and 2 PCI slots. That's probably as close as you'll get to the configuration you describe.
Reply 4 of 9, by obobskivich
Out of curiosity, why do we need a PCI-X card for SATA? What's wrong with PCI? 😕
Also, I'm fairly sure the Voodoo5 is AGP 2x only - I've seen mods that try to put one into an AGP 8x slot (this requires cutting) and it still will only enable up to 2x. So you only need a board with appropriate supports for that, and the PCI-X slot. I would look for workstation/server boards from around the time of the Voodoo5 - it'll be your best bet for finding PCI-X. Getting AGP and PCI-X together, and not having something too modern for the Voodoo5, is probably the bigger trick. Maybe the Tyan K7 Thunder for example? It lists AGP 2x/4x support for its AGP socket, and has five PCI32/64 slots.
Alternately, look at a PCI SATA controller and have a much wider range of options. 😊
Reply 5 of 9, by Stojke
Well, i do have PCI only SATA controller as well, but the 4x SATA2 Adaptec one is better.
I would like to know what are the best possible if i ever run into some, but no PCI-X is also OK. As long as Voodoo can work with out the need of neutering 🤣
Reply 6 of 9, by ratfink
MSI K7D Master/Master-L if you want to use the dual athlons and voodoo5... but pci-x slots are near the agp. Seems to work ok with a modern-ish psu too.
Seems the Tyan Tiger S2466 is similar.
Reply 7 of 9, by obobskivich
You should be able to get SATA2 on PCI; not that it generally matters for performance (I'm assuming when you say "better" the Adaptec probably has more features, like RAID; which does matter). Like this: http://www.amazon.com/Vantec-6-Port-SATA-Host … SATA+controller
As far as the "best" boards - I'm guessing dual Athlon is probably where you're going to be looking based on what I've found, and other replies you're getting. If you're fine coming off the CPUs a bit, there should be a variety of Pentium III and single Athlon boards that will do alright.
Reply 8 of 9, by misterjones
I have a Tyan Tiger MP based dual Athlon MP machine right now (typically running CentOS but I needed it for WinXP temporarily). Has 4 PCI-X and 2 PCI slots as well as a 2x/4x AGP slot.
Reply 9 of 9, by Unknown_K
Something like this?
http://www.ebay.com/itm/Tyan-S2466N-Motherboa … d-/201025299530
You would have 2 PCIX slots one of which should be far enough from the AGP to allow the Voodoo5500 some breathing room.
Boards with full PCIX slots tend to not have any AGP.
