Case recommendations?
First post, by snorg
I'm looking for 2 budget cases so I can get some of these older systems back together.
I don't need anything super fancy, no LEDs or bling, just plain matte black is fine.
Toolless would be nice but I realize for my budget ($25-$50) that is probably unlikely.
I found a Diablotek case which looks ok, it doesn't have a power supply but I've got old power supplies I can use.
Anyone worked with them or have recommendations? I've also found some Thermaltake cases that look ok but that would bump my total expenditure closer to $100.
Thanks in advance.
Reply 2 of 28, by ODwilly
http://www.newegg.com/Product/Product.aspx?It … N82E16811129187 these Antec cases are nice. No frills, cheap, OK cooling.
Main pc: Asus ROG laptop. I7-6700HQ, GTX 960M 4gb, 16gb DDR4.
Reply 3 of 28, by Tetrium
I recently bought 3 ATX cases as I reckoned it would be getting harder to find ATX cases with top-mounted PSU in the near future. They were around 30 euro each. 2 of them were coolermasters and 1 was a gamble (unknown brand, but the case at least looked nice)
My retro rigs (old topic)
Report spammers here!
Reply 5 of 28, by obobskivich
There's a Silverstone case that runs around $30-$40 if I remember right. It isn't full ATX though:
http://www.amazon.com/Silverstone-Tek-Micro-A … 92070131&sr=8-2
I also came up with a pair of Thermaltakes:
http://www.amazon.com/Thermaltake-Black-Editi … 92070191&sr=8-3
http://www.amazon.com/Thermaltake-WingMA-VI50 … 92070200&sr=8-1
I'd agree with avoiding DiabloTek.
Reply 6 of 28, by Stull
I bought one of these recently. They sometimes go on sale for $19.99 with free shipping. Kind of flimsy metal but it gets the job done.
Reply 8 of 28, by sliderider
PeterLI wrote:
Sometimes buying a 386 / 486 on eBay with everything in a case is cheaper overall I think. 😀
But be careful of proprietary cases that have the card slots oriented in the wrong direction. You'll never get a standard motherboard to work in one of those.
Reply 9 of 28, by snorg
These aren't for that system, though. I have a naked dual socket A motherboard and a P-Pro that is in a ratty case right now that could use a new one.
Reply 10 of 28, by bristlehog
I have recent negative experience with this Silverstone case. For $140 its build quality was pretty lousy: it can't even be assembled without tearing parts of it away! I would stay away from Silverstone.
Also, I had experience with these cases:
Fractal Design Define R4
Cooler Master Stacker 831 SE
Their build quality is high. However, Define R4 cannot adopt full length ISA cards without being modded (or you have to get rid of HDDs and use CF cards).
Hardware comparisons and game system requirements: https://technical.city
Reply 11 of 28, by retrofanatic
That case doesn't even have external 3.5" drive bays...gross.🤣
Just keep looking..I know where I live cheap atx cases are very easy to find...there are so many chinese companies that make lower end options. In this case, I would actually stay away from name brands like antec unless they are older used atx cases because the newer cases they make usually are trying to be 'sleek and minimalistic' (but do it in a cheap way) to appeal to the newer generation of win7 and win8 users (blah) that don't use things like floppy drives anymore..and leave out essentials like external 3.5" bays...the cheaper and older models usually are less sought after by mass market and there's always a better chance of getting a case with more flexibility for retro builds.
Look for more generic brands in less mainstream computer stores and websites.
Reply 12 of 28, by Tetrium
retrofanatic wrote:
That case doesn't even have external 3.5" drive bays...gross.lol […]
I've noticed this, the ATX cases I bought were all very light (which usually means they did something cheap). I really like my now old AOpen cases though which I used for several of my builds. Heavy, thick material, sturdy, I like em 😁
The new cases? I'm not really impressed. Also people tend to ask a lot of money for their old good quality cases and they are often quite worn out, scratched or are missing stuff. At least here in The Netherlands
Reply 13 of 28, by obobskivich
Could you be more specific regarding what parts had to be "torn away" (and if you could clarify if this was actual cutting of metal, or simply removing some screws/bolts and removing/replacing a panel)? From the pictures you linked to, the case appears pretty standard for an HTPC case - somewhat cramped, not the most ergonomic thing in the world, but otherwise pretty normal. I could see having trouble with full-length ISA cards or large PCI Express cards, but for a basic HTPC with an mATX motherboard and integrated components, it doesn't look too demanding.
Reply 14 of 28, by bristlehog
There's a rubber line over the removable cage that contains HDDs and 5.25" slots:
It's purpose seemingly is to reduce vibration or smth alike. However, since the upper lid is sliding, that rubber line won't let it to be put in place:
The lid just touched that rubber line and stopped there (well, it's rubber after all). If I applied much force, the lid would move some half an inch and then horrible sound of rubber being torn from its metal base could be heard. It moved relative to its base to which it was glued, but not relative to the lid!
I had to tear that rubber line away to be able to close the case:
I will have to think something about the glue remains. Maybe I'll remove them with some dissolvent or glue something less thick over instead of that rubber.
Reply 16 of 28, by bristlehog
I edited my post so that hopefully now it's obvious why I had to tear the rubber away.
BTW, it's an EATX case, at least claimed to be so. It also can adopt full length ISA cards, that was the reason I made a buying decision.
Reply 17 of 28, by Stull
Psst...hey:
Reply 18 of 28, by retrofanatic
Stull wrote:
Psst...hey: http://i.imgur.com/GrM3waF.jpg :lol: […]
Psst...hey:
Thanks for spotting that..I stand corrected...I was reading the specs and didn't even look at the photos that closely.
The specs say nothing about an external 3.5" drive:
SGCC steel ATX Mid Tower
2 x USB 2.0
Audio In/Out Front Ports
3 External 5.25" Drive Bays
2 Internal 3.5" Drive Bays
Oh well..I still don't like that case anyways and using that external bay means you have to give up one of the internal ones.
Reply 19 of 28, by kithylin
just go with an Antec Three Hundred, they're usually about $50, sometimes a little less. Excellent cooling, enough for a dual-cpu server board and 6 x 15k rpm hard drives just fine (all 6 hard drive bays are directly in-line with the front two 120mm fans, so the fans cool the drives directly). No external 3.5" bays but if you're going ATX, a usb floppy drive works just as well. And they use solid steel throughout the chassis. And the front fans blow -through- the drives long ways, so the hard drive rack doesn't impair airflow at all.
