First post, by JaNoZ
- Member
Hi guys,
Anyone happen to have an S3 Trio32 PCI?
i have a card without the bios chip mounted and i would like to have a copy of the bios if anyone could help me out?
thanks
jan
Hi guys,
thanks
jan
I'll have a look in my attic if I have one (probably not as I only took mostly Virge's, but you never know 😜 )
How would I go along in getting that BIOS file???
I'll be needing some assistance there, but perhaps someone else here already has the file ready to be uploaded.
Nevermind, I looked in my kiwibox of pre-Virge S3 cards and all I seemed to have are Trio64's and a couple Cirrus Logic cards
I am not using a S3 Trio32 in any of my systems but I think I perhaps have one.
If no other member has a card in his/her system I could try to find one.
I do also need to know what application to use for dumping the bios to a file.
[edit] I did only find S3 Trio64 cards [/edit]
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
yeah, I only have trio64 ones as well...
I'm searching for a Trio3D PCI. I'm pretty sure I saw one on ebay a couple of years ago but have seen only AGP cards since then.
I have Diamond Stealth SE PCI, will it be okay? What software should I use to get BIOS dump from it under Windows98SE?
I am not sure what program would be capable to read it out from the pc or in win98.
I was hoping some has a eeprom burner to read out the eeprom.
I have one, and reading it as a 27c512 or 27c256 or maybe even 27c128 would succeed in reading all the data stored in the eprom.
Which i need, the roms probably are uv erasable so emptying them would be not possible for you.
I see it is probably possible from dos and uniflash, there should be used -pcirom and a pci device nr.
Maybe someone uniflash guru here at vogons can help out a little bit, i am no expert.
Thanks for all the replies so far, i would like to try out the trio32 just for kicks instead of having to throw it out.
I have loads of eeprom's and eproms of this type but i need the raw data 😉
//edit
Btw the sweetheart card looks exactly like :
http://www.ebay.com/itm/PCI-Video-card-S3-Tri … A-/131112707983
But only has a trio32 on there instead, just like the stealth SE indeed.
Come to think of it, maybe that same bios file for the trio64 will also be compatible to the trio32.
I see the memory bus is selectable through a jumper, maybe the trio32 is a 64 with jumpered memory bus to 32bit instead of 64 for the trio64.? hmm.
And i see there is a 27c512 on there, on the ebay card, but probably the vga bios will show the text trio64 and we dont want that do we?.
I want 32bit powa.
here is dump from my Stealth SE 1.02
http://www.vintage3d.org/data/trio32.BIN
Here are two other BIOS files:
http://www.vgamuseum.info/index.php/vlasks-co … 3/188-s3-trio32
The OP didn't mentioned the brand of his card. If required, I could read out the BIOS of a STB Powergraph/32.
Youtube Channel
I have no clue what brand / model the VI-941 is.
I have one, brandless. The only problem is, I have no idea how to dump BIOS.
You can do this with debug, but imho much more convenient is to use NSSI and then choose Save ROMs to File.
Youtube Channel
