First post, by Dougal
Do I need to change any jumpers on the SB 32 CT3600 in order to enable to MT-32 to interface with the Gameport ?
Win 7 : Core2Quad 2.4Ghz, 4Gb Ram, Audigy 4 Pro
Win 98: Pentium III 600Mhz, 448MB Ram, Matrox Millenium DualHead 32MB, Sound Blaster 32, Roland MT-32
Win 98: Compaq Armada 7400 P2 333Mhz, 192MB Ram, ESS AudiDrive 1879 with Wavetable
Reply 2 of 10, by Dougal
Everything is still fresh on the computer as it is work in progress.
The SB 32 is installed and running perfect in Windows 98 but I did not install yet the DOS drivers.
I plugged in joyport midi adapter into the SB and there is 2 MIDI cables but not marked IN or OUT, so i tried each one inside the MT-32 and tried Doom and Ski or Die but both games did not interface at all with MT-32. I tried running the games in a Command Prompt in Win98.
The SB 32 works fine and in games (command prompt) I can select AWE32 and it works fine.
The MT-32 is working perfect on my not-retro pc connected to Audigy 4 Pro
So hardware should be good. Maybe it is a driver issue ? The Sound Blaster is using Windows 98 drivers.
Reply 3 of 10, by 5u3
Doom only supports General MIDI, not MT-32. There is a way to set up the MT-32 to emulate GM, but that is a task for when you got the MT-32 working.
If you run games from the Windows command prompt, the Windows SB drivers might interfere with the MIDI port and route the MIDI signals elsewhere. I'm a bit rusty on the details, but I remember you can select the synth for MIDI somewhere, and it should be set to "External" synth.
Generally, DOS games expect the MIDI port at address 330h for MT-32.
Reply 4 of 10, by jwt27
Doom should at least produce some sound on MT-32, but will sound completely wrong without the GM emulation patches.
Ski or Die requires intelligent mode, so you'll have to run SoftMPU before you'll hear anything.
Have you tried a different gameport->MIDI cable?
Reply 6 of 10, by bjt
So it does, didn't know about that one. I've added it to the compatibility list.
Reply 7 of 10, by sliderider
And here's the Roland GM emulation in action.
https://www.youtube.com/watch?v=FhNZ8YgFk1M
Reply 8 of 10, by Dougal
I've FINALLY managed to install the SB32 dos drivers. It was a pain as the driver DOS installation was meant for DOS 6.22/Win 3.1 and refused to install but I managed to manually install it. (Copied the necessary files & modified the config.sys & autoexec.bat).
Now, i've got one of those gameport to MIDI adapters. Is there anything else I need to setup in order to use the MT-32 with this set up ?
Reply 9 of 10, by Dougal
Ok all sorted. My Gameport to MIDI adapter was crap. Had another (different) one on order which arrived today and set it up and everything works great. AWE-32 works in supported games, MT-32 works in supported games and General Midi (using MTGM patch) works fine too.
Reply 10 of 10, by sf78
I also encountered a similar problem just now. I tried two different sound cards (SB32/YMF724) with MT-32/SC-55 and got nothing out of them. Finally tested the game port-to-midi -cable and noticed the wiring was way off, so shop carefully. Only problem is to tell which of the cables are crap and which are not as they all look-alike. 😒
