First post, by andrewls
Hi guys,
First question: does anybody have any experience of any model of Creative PCI sound card running natively under DOS and working with Voyetra Sequencer Plus/Pro?
I have installed a CT4810 PCI card and have the soundblaster drivers working with Creative SB DOS drivers but can't get any of Voyetra's .COM driver files to load. All I want is the VAPIMPU.COM to load so I can use the Midi port. (I am using the correct BLASTER string, etc.) I can get the TAPISB3.COM driver to load if I set the blaster string to the SB16 emulation DMA but Voyetra runs really slowly even though the computer is a 1.2 ghz HP thin client.
Any tips on how to trick Voyetra into running properly would be great - maybe there are switches in loading the driver that might help?
Thanks for any help!
