Reply 21580 of 29869, by pan069
Shponglefan wrote on 2022-04-28, 23:50:
NyLan wrote on 2022-04-27, 20:03:
Created my Windows 3.11 WFW 8x floppies set :love_you_gesture: […]
Created my Windows 3.11 WFW 8x floppies set 🤟
Comparison between mine and official one :
That's quite good! What are you using for labels?
I was about to ask, "why" are you using labels, since the containers are transparent... 😀
Reply 21581 of 29869, by Meatball
Tested a bunch of Athlon Thunderbirds CPUs over the past week. 4 out of the 8 are dead. 2 of those 4 worked at first, but then 1 began to smell like it was cooked/ozone at boot up (and never recovered), and the other just plain gave up the ghost and died a few reboots later. 1 of them I can see it had a corner cracked off, and the final dead one never worked to begin with.
What was nice about all 8 was each of the L1 bridges weren't factory cut, so there was no need to pencil them in for overclocking. (I didn't get a chance to overclock the dead ones, of course...)
I never owned these in their heyday. Is it business as usual to run into so many dead or soon to be dead Thunderbird Athlons?
Reply 21582 of 29869, by BitWrangler
They are easy to kill with excessive heatsink force or displacement while trying to assemble.
edit: oh and if you try a super weak spring clamp and it's not sitting exact they'll cook themselves as soon as you apply power... no finger testing, they're done by the time you go ouch.
Reply 21583 of 29869, by Shreddoc
Looking back, the design is ridiculously fragile.
Not to take away from their achievements. Awesome, awesome processors, it was a very exciting time.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 21584 of 29869, by bakemono
I saw Zilog Z280 CPUs in PLCC-68 for sale on auction site, and then found a blog post about people using them for small homebrew boards. I was starting to feel the urge to design my own board. Then I looked through the Z280 manual and changed my mind... The banking/paging scheme they used to extend the address space would not be very good at handling larger programs. So in the end it's not that different than a plain Z80, and I already have Z80-based systems to play with. I also looked through the Z380 manuals, and I like the instruction set for that better, but Z380s are not obtainable (and the only physical package I saw mentioned was QFP). Time to escape this rabbit hole 😀
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 21585 of 29869, by BitWrangler
Look at this real interesting hole though, the eZ80! 🤣
Reply 21586 of 29869, by PcBytes
Meatball wrote on 2022-04-29, 01:38:
I have quite a few dead Athlons and Durons.
The reason of dead CPUs is simple - either no thermal paste applied (found this out the hard way with an Applebred Duron that started smelling of napalm, but the ceramics fail the same way. That thing failed so hard it burnt a Raidmax fan I had on the case...) or heatsink not installed properly (this was so common that I can't even count the times I've seen it done.)
That's why I love Pentium 3s - they can take much more abuse than an Athlon or Duron, and they don't go up in smoke if the HSF ain't installed properly.
Oh, and there's cracked cores. I lost two CPUs from both sides that way - an 1.1GHz T-Bird Athlon and a 1.1GHZ Coppermine P3 SL5QW. The former had severe chipping at the sides and the latter's core was literally cracked in half.
Reply 21587 of 29869, by chris2021
What processor is in the Tatung?
Reply 21588 of 29869, by Alistar1776
I got a Socket 462 system up and running with Win98SE today after hours of trying other things, trouble shooting issues, etc. It was very rewarding to see that "Welcome to Windows 98 Second Edition" box materialize on the screen for the very first time! 😊
Reply 21589 of 29869, by Joseph_Joestar
Tried the Goldmine demo which comes on the Audigy driver CD. It's a pretty neat showcase of EAX Advanced HD (aka EAX3).
I like that the demo shows you how everything sounds with EAX3 on and off for comparison. The Environmental Morphing and Exclusion examples were pretty impressive, especially when used with a 5.1 speaker system. I could have gone without the annoying crow sounds though. Terrible choice for sound demonstration.
Reply 21590 of 29869, by chris2021
@Alistar1776
Can you talk about this? I had more or less immediate success triple booting a foxconn based socket a system (win2kpro,winxp,rhel3), despite frequent no starts and occasional lockups. The mobo and ram were presumed new, as was the dookie p4/amd ready p/s. Hard drive was used, but probably not a lot. Others have had issues with socket 462 and it makes me curious. Would like to learn more details.
Reply 21591 of 29869, by appiah4
The 3300uF 6.3V caps on my Biostar P4M890-M2 had bulged and leaked so I cleaned and recapped them with new 3300uF 16V low ESR caps. Hopefully my S775 Win98 PC will POST once I put the board back in 🤣.
Reply 21592 of 29869, by Meatball
Thanks people. I was too lazy to put thermal paste earlier on on the testing, but after the 2 died, I moved to a bigger heatsink with paste, which could also clamp onto three 3 socket pegs.
I’m exchanging the 2 which never worked, but taking the fall for the other 2 I probably crispied.
I also bought up as many “cheap” “C” models as I could find as insurance for the future.
Reply 21593 of 29869, by Kahenraz
Despite this attractiveness, this is why I've tried very hard to stay away from collecting these platforms. I don't want to get into collecting vintage parts that are so delicate. I enjoy having the luxury of being and to make mistakes and not have things go up in smoke.
Between Coppermine and the Pentium 4, I'm satisfied with this era.
On a similar note, has anyone ever tried using a thermal pad with these processors instead of paste? I use these regularly when my Pentium 3 processors and it works just fine.
Reply 21594 of 29869, by brian105
20220425_213806.jpg?width=503&height=671
Cleaning a 7950GT and repasting. Put Kryonaut and the thing still idles at 50c.. idiots at nVidia made the reference cooler a 1-slot blower solution, and Foxconn kept that solution. It actually doesn't get that much hotter when playing Portal, but the fan always sounds loud and terrible.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 21595 of 29869, by PcBytes
Had to recap my ABIT BE6-II again. Have you guys ever encountered failed, dried out Panasonic FL caps? 8 buggers total.
The ones that were good were 3 Rubycons on the EC12, 15 and 16 spots since those were pulls from a mainboard I had that I knew had good caps (GB 8IG1000-G, dead northbridge).
I ended up installing 8 "new" Panasonic FL caps 6.3v 1500uF from an discarded ASUS M2NPV-MX and now the board POSTs all times, unlike before when replacing an ethernet card rendered the machine unable to POST. Still couldn't get it to detect a RTL8169SC card I had, but a standard RTL8139C dated 2001 (just like the BIOS that's on the ABIT) worked fine. Also tested a Intel PRO/100 card and it got recognized and didn't render the mobo unable to boot.
brian105 wrote on 2022-04-30, 05:35:
https://media.discordapp.net/attachments/424000117717073920/968325125667688538/20220425_213806.jpg?width=503&height=671 […]
AFAIK ASUS did that too. It's the prime reason why the card sits dead in my closet. Even though mine is a 7900GS, it isn't much far off in design.
Reply 21596 of 29869, by Nexxen
What is that ring on the core? Sadako rev?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 21597 of 29869, by Alistar1776
chris2021 wrote on 2022-04-29, 09:39:
@Alistar1776
Sure! So, system specs are an MSI board, dont know what chipset at the moment. Cpu is an Athlon XP 3200+ 1.1ghz, about 750mb ish of DDR, thats only because of Win98's 1gb ram error. Gpu is an ATI Radeon HD 4650 AGP, no drivers yet. Which can i get help with that? And for sound is a Creative Labs Sound Blaster 16, i also need drivers for 😅
Now my issues started when I tried to run DOS 6.22 on it, just testing my written floppies, ya know. Went to boot to C and it gave me "unknown file system, entering Grub Rescue mode"
Tried to boot Win2000 CD, same error. Unknown filesystem.
Tried my Win95 on floppy, but disk 5 had a corrupt cab file, so that was a scratch.
Then i finally got Win98SE to install after a few tries and finding out i needed a boot floppy 😂
So, in short, my issues were purely getting an OS on the system. I blame my limited, yet growing knowledge of older systems honestly 🤣.
Reply 21598 of 29869, by stef80
Meatball wrote on 2022-04-26, 18:21:
The 2nd motherboard I ever bought was an Intel D815EEA w/Pentium III@733MHz, which replaced an Asus P2B w/400MHz Pentium II. I installed it into some kind of translucent green case. I think this was during the iMac G3 "berry" rage. Anyway, this board conveniently included a 900/100MHz CPU (one of the last socket 370 PIIIs I wanted to complete the set).
Nice board. This is top of the line Intel Desktop Board for Coppermine. It has onboard VGA, Intel NIC and Creative PCI audio. Basically, all you need is decent graphics card.
Reply 21599 of 29869, by brian105
Nexxen wrote on 2022-04-30, 08:21:
I have no idea what it is. I tried to get it off with IPA but it didn't change. The bottom of the cooler which sits on the die doesn't have this ring.
Closer shot:
