Reply 24180 of 27549, by Thermalwrong
Thermalwrong wrote on 2023-04-01, 00:50:At last I've sort-of managed to troubleshoot something using my oscilloscope. I posted a picture of this board the other day wit […]
At last I've sort-of managed to troubleshoot something using my oscilloscope. I posted a picture of this board the other day with the front and back traces overlaid - I got this board a couple of years back as someone else had attempted to repair it and not got it working. I couldn't do much better although I did repair a bunch of the vias it still wouldn't do anything.
This is a WTC POP-3254 and the example shown on the retroweb appears to be in a worse state than my one. It's a rather old and basic 386dx board with no cache and the battery had destroyed some traces and vias by the 82c206 chip. It was coming out of reset and the clocks were working, but it didn't do anything.
Checking with the scope on the BIOS EEPROM I could see that there were signals on both the address and data lines, but some of the address lines seemed to have the same signal patterns and went from 5v to 2.5v which didn't seem right, most signals went to a lower voltage for a low signal.Washed it up in the sink because this board has clearly been exposed to the elements and there were some white marks around most of the pins where I think the lead was leeching out. It cleaned up nicely but that didn't fix anything.
One of the 74LS373 chips had been replaced and socketed by the previous owner so I decided to pull everything in that area off, test it and check the connections of the traces, including the 82C206:
The pads/legs of the 82C206 were a bit corroded so that had to be checked too - there were bad VIAs hiding underneath it. Laboriously tracing and checking each trace that the 74LS373s attached to. The 74LS373 that wasn't replaced was bad after all, but its traces were in better shape.WTC-POP-3254-tracing.jpg
A front and back picture lets me trace all the lines in Krita and see all the points they pop up - this is doable because this is a comparatively simple 4 layer board with VCC and GND on the inner layers, with signal routing on the outer layers only.
You can see how it looks for tracing here: Re: What retro activity did you get up to today?
This has the underside as the bottom layer with a filter mask layer to adjust the tint. The topside layer goes above that with the Blending Mode set to Lighten - which gives a really nice kind of overlay and the layers are different colours so it's easy to tell what I'm following. Some more layers on top with the set of pins I'm tracing. I'll definitely use this method again in future, I was able to find a bunch of broken connections by following the traces on the screen.
Then drawing a marking by the pin so I can tell it's been checked - only one wire had to be run on the outside, that's the one marked X.Put it back together and put the 82C206 back on, it powered right up! Yay 😀
For some reason it has a 33MHz Intel 386, but the clock crystal is 50MHz for 25MHz CPU speed. The BIOS doesn't appear to be online and it came to me with no sticker on the EEPROM window, there was a big gap in the ROM file so I was worried the ROM was damaged, but it's fine after all. It's an AMI BIOS with a BIOS string of EOX3-6069-083090-KM
This thing is old enough that it has bios settings configured either with easy OPTI setup which has few options like wait state, or advanced OPTI setup where settings are configured by changing register bits, it's guided but it shows which bits are being altered for 11H, 14H etc. The board's from mid 1991 going by the chip markings but the BIOS and design both say '90, so it's probably the oldest computer I've got along with the Tandon motherboard.edit: ergh okay so it's not working entirely. Stuff like keyboard works and I can change settings / save settings in the BIOS, but the computer can't boot from a floppy disk. Could that be a problem with DMA? That's handled by the 82C206 and there's a cluster of damaged traces there that were repaired.
It just says insert BOOT diskette and I've tried two known good drives, it does the track seek on boot so I think it's solely down to being unable to read the data.
As a follow up to this, I've been trying to figure out what's wrong with this POP-3254 / OPti 381/382 chipset 386 motherboard. The board posts, runs from a hard drive and can run programs, but it couldn't read floppies and PCM audio was coming out as a garbled mess in any test - that's a DMA problem. The 82C206 chip handles DMA and I fixed some traces that were broken underneath it as well as some of its traces that run over to the KBC - that's how it came back to functioning.
I could see that DMA was being processed like a DRQ was happening and there was a DACK following from what I could see but still garbled noise. I was getting ready to buy a new 82C206 and replace that but on a whim and following some traces from the 82C206 data pins, I pulled off the two 74F245 chips here, which from what I can tell connect it all to the bus - looks like they were in the path of the corrosion that this board was subjected to as the solder for them was tough to remove:
Both of them tested okay out of circuit but they had some dirt under them and the legs were pretty discoloured. I cleaned it all up a bit and put them back to get the board back to operational, again on a whim because I didn't think this would have fixed anything, tried a game and now sound works!
So now the DMA for both floppy and sound is working perfectly again and I don't really know what I fixed. Maybe the 2x 74F245 chips were used to make up 16 bits and one wasn't working because of dirt under the chips causing connections where there shouldn't be, causing the garbled-ness? But the lower one may have worked to allow everything else to function? I don't know enough about this stuff yet.
I'm really glad this is fixed since I was going to get an 82C206 but couldn't see how a board could be so otherwise functional with just some badness on the DMA. The more I use this thing I see it's a pretty odd board, the original BIOS was from like 1990 and would get angry if I installed 1MB SIMMs, limiting the board to 2MB of RAM. That was fixed by putting another board's BIOS on it - thank goodness for the retroweb's comprehensive search functions and BIOS repository: https://theretroweb.com/bios/?chipsetId=366
I put the 1991 BIOS from a Biostar MB-1325PD on it - and it works! Now the BIOS is the much more 'modern' green/purple/brown AMI BIOS I'm more familiar with.
Normally I wouldn't try random BIOS files but did you know that many of the Opti 381/382 chipset boards are essentially identical?
There must have been a reference design, these ones are all exactly the same down to the placement of the 74' logic chips and the RTC circuitry.
Tempted to borrow a crystal socket from another dead board along with its 66MHz crystal, the chipsets are marked as 25MHz but now I want to see if it can do 33MHz since this is a 386DX-33 chip.
