Been trying to get this Abit board to work. Those three bulging caps were in slightly worse condition than I could've guessed from the ebay pics:
I got it to power up after replacing those! Now just scrolling through the BIOS settings... WOW. It has like twice as many settings as a "normal" full-option BIOS, like in the P3B for example. You can even, uh, overclock the keyboard controller from 4 to 18 MHz! No idea why but it's awesome to have. Each setting has a detailed description too, unlike in any other BIOS I've seen so far.
That said though, I can't get it to work reliably. It crashes like half the time during boot-up, but then works okay if it eventually does. Except the ISA slot doesn't seem to work at all, it hangs immediately when running SETUPSA with a YMF719 card inserted.
