Reply 6900 of 27596, by liqmat
bjt wrote:
badmojo wrote:
Very cool machine bjt - nostalgia coming off that thing from every angle. Where will you set it up? Front and center in the lounge room one assumes? 😜
Haha, would love that but I'll settle for anywhere out of the shed and in the house 🤣
Great looking machine. Love the red led panel. In 1992 I had a Tandy 2500 386 SX-25 with 4MB. Not quite as sexy as your machine, but I actually did genlock work with a Cardinal SnapPlus ISA video editing/overlay card installed in that little machine. All the software ran in DOS. Amazing what we did with so little.
Reply 6901 of 27596, by Jade Falcon
Rank BANNED
BANNED
agent_x007 wrote:
Well, if you talking about spikes/drops in cache speed I think they are related to inclusive type cache of Nehalem CPUs (L2 + L3 […]
Jade Falcon wrote:
Yeah the rampage motherboard should have given it away.
That aside whats up with the cache test?
Well, if you talking about spikes/drops in cache speed I think they are related to inclusive type cache of Nehalem CPUs (L2 + L3).
I tried switching off Prefetch (didn't help), tried locking CPU to NB clock and make NB clock 2x DRAM Effective clock - nope, drops are still there.
They only show up after L1 cache is full, and on both L2 and L3 (in certain intervals).
This chip has full 12MB of L3 cache available to it (on top of 32kb L1 and 256kB of L2) wish DOS could use it as "standard" RAM 😁
Score on 4,49GHz (NB=3906MHz + DRAM=1951MHz "192-bit").
Yeah I was talking about the spikes and drops. and yeah using the cpu's L3 as ram would be nice
Reply 6902 of 27596, by bjwil1991
Going to re-test the C64 PSU as nothing wouldn't get displayed on my screen.
5VDC: 5.07V <-- good news
9VAC <-- going to work on that
The chips do get warm, but I need to test the voltage to make sure they're getting sufficient power.
Reply 6903 of 27596, by Bancho
Started work on my Time Machine tonight. I'm really looking forward to completing this machine and it taking over my 200mmx as my "Main machine"
Initial install gave me no problems. Once i started to introduce the sound cards that's when the hassle starts!
As it stands so far
AMD K6 III+ 450 stock
Chaintech 5RSA2 MATX Aladdin V (REV-E) motherboard
128mb Crucial CAS 2 100mhz ram
AGP 3DFX Voodoo 4500 (Consider changing this to a Voodoo 3000)
Aztech Sound Galaxy Nova 16 Extra II-3D sound card
Turtle Beach Pinnacle Rev C Sound card
80 Gig WD Hard Drive
Pioneer DVD Rom
I have to say i really like the Nova 16 sound card. It is very quiet once you setup the mixer correctly. I am using the pinnacle purely for the Kurzweil Midi. I think is sounds awesome imho! I may add a Dreamblaster S2 at a later date to the Aztech for a different sound.
Reply 6904 of 27596, by PTherapist
Bought a Lava DSerial-550 ISA Serial Card for my 286 and installed it today.
Thought it may solve an irritating issue I was having with regards to the COM ports on my I/O card and inability to detect a mouse etc. I was correct, it worked a treat. Before I was limited to an old 25-pin Serial Mouse which worked great in DOS but refused to operate in Windows and now with the help of this card I can use any regular 9-pin mouse both in DOS & Windows. 😎
Reply 6905 of 27596, by bjwil1991
Tested the PSU Voltage on my C64:
5V DC: 5.07V (passed)
9V AC: 0.63V (failed)
Looks like a rebuild is in order (cheaper than buying a we one).
Reply 6906 of 27596, by CkRtech
bjwil1991 wrote:
Tested the PSU Voltage on my C64: […]
Hey - share your rebuild details if you proceed, would you?
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 6907 of 27596, by psychz
Made the serial XBOX EEPROM reader cable, hooked up the XBOX rev 1.1 on a Pentium4, got the hard drive lock key with PonyProg and LiveInfo and booted into xboxhdm to prepare an 80GB WD Caviar with MS dashboard 5960 and ndure 3.1+unleashx softmod. Now to clean the DVD drive and change thermal paste, and then might flash the TSOP with the team xecuter bios for not having to mess with HDD locks ever again. Could not get the damn live IDE hotswap trick to work, using the serial cable is way easier (and reusable). In the end, played some Kakuto Chojin: Back Alley Brutal 😊
Already had an XBOX but it's kind of nice to spend some time and see step-by-step the transformation of a console (or hardware in general, for that matter), from being a dirty, half-broken and unusable box, to the point of being 100% fully working and enjoyable. Thing is, because I had one since it was new and still used mine till recently, I can't call it retro, even when I realise that I have it for like, what, 15 years? 🤣
Stojke wrote:
Reply 6908 of 27596, by bjwil1991
I purchased a cable like that as well for my Xbox Original v1.6b that suffered a PSU and HDD failure back in 2010 (installed a new PSU in 2010, and the HDD in 2013) from the 10GB to an 80GB Maxtor HDD and it still lives. I just need to clean the DVD drive and install a new belt since the one it has requires smacking the drive to get it to open.
Reply 6909 of 27596, by Unknown_K
Pulled out my Packard Bell CD300 P60 socket 4 system to see if it still works. Has one of those RTC chips soldered to the board but the date and time is still correct.
Reply 6910 of 27596, by amadeus777999
Could you take a pic of the board?
Reply 6911 of 27596, by mongaccio
I did repair the power supply of the 1541 disk drive clone a couple of years ago.(dc 5 and dc 12 v) I had to forcefully open the plastic case with some cutting tools, that was the hardest job. Once inside, there were 2 regulators , the 7805 and 7812. One of them was broken, replaced it with a new one, glued the case back , all done. The most difficult part is opening those damn bricks.
By the way, i did some major maintenance to my c128 setup. The main problem was the datassette: the motor kept spinning , even when no commands were given to load a program. Downloaded the schematics, and found out 3 possible causes: 1.the power transistor that powers the motor, a tip 31. 2. the logic gate that is in series to the tip31, 'U30', if i recall correctly which is normally open, broke up and remained closed. 3. the CPU I/O (and that was a bit of a worry)
144.45 KiB
So, i tried to replace at least the first 2 - and guess what, it worked again! Bought some extra spares , just in case.
Had some fun with the Great Gianna Sisters
169.72 KiB
I've also fixed the green led of the 1541/2 drive. It was strangely shorted on the back of its pcb, guess it was like that from production.
Also the monitor/tv needed the Scart plug fixed (solder joints were weak), and a nice adjust on the vertical amplitude (both problems very common on mivar tvs)
Last, but not least, a good Azimuth regulation for my datassette. I have to say that everything works fine now.
Reply 6912 of 27596, by Unknown_K
Looking for something in particular?
Reply 6913 of 27596, by aop
Been having serious stability issues with my retro PC build since last night.
I suspect the motherboard (Gigabyte GA-5AX rev 4.1) caps are bad since the instability is really random. Sometimes the computer just freezes on start up but once you get it warm it seems to work OK (tried running Super PI with it and atleast 1M and 2M go through, didn't have time to test longer ones).
I played a lot of Interstate '76 on it yesterday and the computer started crashing after a gaming session when I started to install and try other games.
I managed to mess the entire Windows 98SE installation when I swapped CT4780 SB Live to a SB0060 and the computer crashed while it was installing drivers. After that no drivers would load on start up and I had to format the hard drive and reinstall Windows. Currently it seems that the SB Live cards are most likely to trigger the crashing but I think I had some crashes even without them installed.
Should I recap the mobo just to be sure? There is no visible trouble with any of the caps but they are random noname brand (Choyo) and IIRC caps can be very much dead even if they look fine externally.
I've been trying to build a Super Socket 7 retro PC over 1½ years now and I'm extremely bummed now that I thought I had a working retro PC and then it went crash happy overnight.
Reply 6914 of 27596, by luckybob
I always believe it to be a good idea. And it can't hurt the board unless you mess it up.
it could be as simple as one half-bad cap that throws the memory slightly out of spec and causes all the problems.
I've gotten really good at recapping things.
Reply 6915 of 27596, by aop
What series of Rubycon caps are OK for recapping motherboards? ZLG is available, affordable and the ESR seems low enough but I haven't seen much mention of using them to recap mobos. Every single cap on this mobo is rated 25V 330uF.
Reply 6916 of 27596, by luckybob
honestly don't believe it matters much for a SS7 board. Most of these are just going to be large decoupling caps or caps for the dc/dc power conversion. Personally, I buy the least expensive Nichicons I can get at Mouser.com . I believe low esr was more important in the pentium 3-4 era where power draw was immense by comparison.
Also, how is your power supply doing? That can also be a factor.
Reply 6917 of 27596, by aop
It's a 300W HEC and last time I opened it it looked OK. I could try with never Corsair CX400W (it has only 130W combined 3.3 V / 5V).
Reply 6918 of 27596, by gdjacobs
Pre MMX, the CPU regulators were often linear, so ESR was even less of a factor.
Reply 6919 of 27596, by luckybob
even the 300w unit is overkill. I'd check the voltages, under load, of that psu first. Anything more than 5% off, the psu goes in the trash. I've had bad power supplies kill stuff, I don't take any chances with that. Special, expensive, power supplies are worth re-capping but your average ATX? hells nah.
