Reply 17200 of 27549, by kolderman
HanJammer wrote on 2020-11-19, 00:48:
kolderman wrote on 2020-11-18, 23:08:
the_ultra_code wrote on 2020-11-18, 22:45:
Finally got my Asus P5AD2-E Deluxe in the mail today. Got it cleaned, updated the BIOS, and installed Windows ME on an SSD for i […]
Finally got my Asus P5AD2-E Deluxe in the mail today. Got it cleaned, updated the BIOS, and installed Windows ME on an SSD for it.
With all onboard devices turned off, I managed to install drivers for all but one PCI USB device. That's right, all but one. Using the unofficial 82.69 Nvidia driver, I was able to get my 6800 Ultra PCIe to work under ME (runs 3DMark200 and Deus Ex just fine, although I did notice that my start menu was a bit glitched.
What on earth is that game in the second pic?
Deus Ex - best game ever.
Eh one I've yet to play... Was not expecting a sword.
Reply 17201 of 27549, by ultra_code
kolderman wrote on 2020-11-19, 01:06:
The Dragon's Tooth. The best melee weapon in the game. You can insta-kill basically anything from behind, maybe 2-3 hits if not, IIRC. Add the melee bonus augment, and you're a melee-killing machine.
It also allows you to butcher bodies so they don't exist anymore ( }:D ), and break weak metal objects. You get it after completing the Hong Kong chapter.
Builds
Reply 17203 of 27549, by BetaC
kolderman wrote on 2020-11-19, 01:20:
Cool. I belive it's a Glide game so when I switch back to my voodoo5 pc maybe this is what I'll play.
It's also an incredibly beloved game, so if the Glide version doesn't work out well for you, you can play it on a modern system with enhancements. Also, be warned that the UI and scopes don't fully scale past a certain resolution.
Reply 17204 of 27549, by kolderman
BetaC wrote on 2020-11-19, 01:42:
Believe it or not I remember when it came out back in the day, just never got around to it 😁. I have heard it's a great game though, and for me the only way to do a great game justice is play it on an authentic build, even better if it's 3dfx!
Reply 17205 of 27549, by ultra_code
kolderman wrote on 2020-11-19, 02:14:
Yeah, I first played it on my P4 rig under 98SE a little over half a year ago. Like a lot of older games, I started playing it for an hour-ish, then didn't touch it for months/years. Came back to it, and got hooked, and quickly played through the rest of it. That playthrough was godly. Such a memorable experience. I then recently installed it on my main rig and patched it with Kentie's executable and DX10 renderer. Not as memorable as the first time, but I had a lot of fun still, and found out just how imperfect the game is (for example, in the Airforce Base mission, there's a power box that you can toggle on/off for a quest, and every time you do so you get XP, even after you've already done it. Thus, you can keep toggling it on/off until you max out every single skill in your skill-tree (yep, broken). But man, do you feel like a god afterwards. 😀 I don't know if other quest-events are also exploitable, probably.
Oh, and of course the memes are godly, too:
https://youtu.be/t3ozAGSfiZw
Builds
Reply 17206 of 27549, by SodaSuccubus
The struggles of deciding what build to put in your single AT case. I can't decide between a ultimate P133-Voodoo rig or a DX2-66.
Speaking of Pentium, quick question: are the VRMs on these boards suppose to get scorching hot with a MMX chip installed?
Benching with a 200MMX and on this particular socket 7 board these giant VRMs get like, burning hot after awhile. As in eventually I can feel the heat radiating from it, if I put my hand near it. That hot. Not even the CPU with a big passive cooled gets that hot!
Iv NEVER felt a VRM get that warm. Ever.
Reply 17207 of 27549, by xcomcmdr
I need to get Windows ME on a machine of mine, but I don't have any that is both a) compatible b) not-compatible with Real Mode DOS games with sound
I don't know why, but WinME attracts me.
Reply 17208 of 27549, by ODwilly
SodaSuccubus wrote on 2020-11-19, 04:38:
The struggles of deciding what build to put in your single AT case. I can't decide between a ultimate P133-Voodoo rig or a DX2-6 […]
Is it running at the correct split voltage? Adding a bit of airflow over the VRM's never hurts 😀
Reply 17209 of 27549, by HanJammer
7881C964DD4AD9C723DC7F7E2661AE25351FAD48
Playing it on 3dfx card would be a bit of a waste. It's Unreal engine based game - it will look much better on cards supporting S3TC. Savage 4, GeForce 2-4 is ideal choice. I believe high-res textures don't even work on Voodoo cards in Glide mode, and you need to play in OpenGL mode.
Reply 17210 of 27549, by HanJammer
VRMs? You mean voltage regulator circuit or do you have a Pentium motherboard with a voltage regulator module? Yeah, the voltage regulator gots burining to the touch on some Pentium motherboards even with P133/K5 installed.
Reply 17211 of 27549, by kolderman
HanJammer wrote on 2020-11-19, 08:35:
https://steamuserimages-a.akamaihd.net/ugc/49866599943638672/7881C964DD4AD9C723DC7F7E2661AE25351FAD48/ […]
Well maybe I will pay it on my other PC with a FX5950U and bump up the AA 😁
Reply 17212 of 27549, by ultra_code
kolderman wrote on 2020-11-19, 09:36:
I had trouble running the game maxed-out on my Pentium 4 672 machine with a 6800 Ultra under Windows 98SE at 1024x768 (by trouble I mean there are plenty of dips below 60fps). Just a heads up.
Builds
Reply 17213 of 27549, by HanJammer
FX5950U will be excellent. Perhaps even with the community created high res texture and model pack (which I do recommend). If I remember correctly there is also DX9 driver which improves lighting and some other things.
the_ultra_code wrote on 2020-11-19, 14:11:
Must have been some sort of compatibility issue. I had trouble playing it on my Riva TNT in 1024x768 in 16 bit back in 2000 and when I switched to GF2MX - all my problems disappeared (I might have even played it in 32 bit). I recently played it on my Athlon 1000 (Orion) and GF2GTS with all the details maxed out (it was plain game without any custom addons) and it was running just fine in 1024x768.
Reply 17214 of 27549, by creepingnet
Got E-mail working in FreeDOS using FLMail on my VersaM/75 last night - I could pretty much "daily" that thing now as if it were a modern laptop at this point.
~The Creeping Network~
Reply 17216 of 27549, by chrismeyer6
I have 4 ultra Xconnect 500 watt psu's and they have been great since new. I use one of them with a socket A system and that system gets a ton of use from my son and it's rock solid stable.
Reply 17217 of 27549, by RetroLizard
chrismeyer6 wrote on 2020-11-19, 16:38:
Does it have any -5v rails?
Reply 17218 of 27549, by ultra_code
HanJammer wrote on 2020-11-19, 15:32:
Nah, I think the game is just demanding. Anytime there's a lot of complex ray-tracing-like effects, for example, or I think complex fog effects and such, it'll hurt performance.
Builds
Reply 17219 of 27549, by chrismeyer6
RetroLizard wrote on 2020-11-19, 16:40:
Yes it does.
Output rails
5V 30 amps
3.3V 28amps
12V 34 amps
-5V .3 amps
-12V .8 amps
+5VSB 2amps
I hope that helps.
