Reply 18220 of 29869, by bjwil1991
- l33t
Did some more testing for the Gigabyte 486 board and it works, but it refuses to retain the BIOS settings, including the date and time with the new RTC Dallas chip I have installed (the one that will allow a new battery to be installed and I think it has to do with the size of said battery).
Getting further here with the board, which is better than before.
The Jetway, on the other hand, needs new capacitors and/or a reflow on the solder joints due to corrosion, however, I got a code C8FF on the POST card, but it went back to ---- on the card (indicates the corrosion on the contact pins for the caps are causing the issues).
