First post, by b_rros
Hi, I recently got an old COMPAQ laptot, it has Pentium 120 Mhz + ESS 1688 for sound and some Cirrus Logic video card. It came with Windows 95. After a cleanup it look as good as new. I try to reinstall Windows with the original disks and most of them don't work, I then try to install it using some unused Windows 95 disk I had around and they didn't work either, so right now it has Ms-Dos 6.22 installed.
So, this computer doesn't have a CDROM drive but it has two PCMCIA slots. Is there a way to use a PCMCIA adapter with a compact flash card to move things between computers? Is there a way to use the CF Card as a drive in Ms-Dos since that is the only OS I can use in the computer right now?
Thanks for any help 😀
And the photos:
