First post, by georgeqgreg
I've got a Vortex2, I got it working on Windows XP with a Asus P4P800S, though only after setting PCI latency to 64. (Sound is great by the way.)
I grabbed this driver (http://www.vogonsdrivers.com/getfile.php?fileid=445) and I've tried installing it on two different computers, and it only seems to do fun things like cause BSODs and simply crash. on the aforementioned Pentium 4 build, after it crashed I actually forgot about and left it running for rather a while. It said my card was plugged into a second PCI bus, (weird.) but the driver seemed to install fine. Then I tried playing a sound and the computer locked up! Oh yeah, the way the driver is supposed to be installed confuses me. Apparently when Windows detects the card (As a PCI Multimedia Audio Card or something I guess) you're supposed to point it to the driver folder on the CD. Well, that entry never seems to pick it up so I used the add hard wizard to add it from that folder manually. Trying to install any of the INFs also doesn't seem to do anything useful. Am I doing something wrong? Missing some important file? It's pretty strange not having some installshield kinda deal like literally any other card on the planet, but whatever. I just want it to work. The sound is fantastic, apparently it works great in DOS too, and... it's my only PCI card with a gameport. It would be real nice being able to use my sidewinder on my Deskpro EN. 🤣
So no one wastes their time reading this thread, I am a stupid moron with an ugly face and big butt and my butt smells and I like to kiss my own butt. Also my card is actually an 8820, in other words, an original Vortex.
Reply 1 of 49, by swaaye
The problem is the drivers are confused by the PCI bus on your board. This happens with chipsets from ~2000 onward.
Edit au30mmed.inf and remove the semicolon in front of this line.
;HKR,Config,DisableBusDetection,1,1
Hopefully that will get the 98 driver working.
Reply 2 of 49, by georgeqgreg
The funny thing is the Deskpro EN is from 1999. (Intel 810e chipset) However, even the Sound Blaster Live does strange things on the deskpro. Anyway, I'll try that out. Thanks!
Reply 3 of 49, by georgeqgreg
Ok, so, I did the edit, and tried to install it the way I did before. There was no crashing but also nothing happened. Then I tried to force it by using it as the driver for the multimedia device thing, windows said the driver isn't designed for this unknown device, but I okd it. Then it froze, I left alone for a bit, and when I looked back... my computer had this unbelievable horse shit on the bottom of the screen, working its way up the screen. Needless to say, I rushed to the camera.
Reply 4 of 49, by Mau1wurf1977
Latest drivers: http://www.philscomputerlab.com/aureal.html
Just unpack, go to device manager > update drivers and point to the folder.
There is a documented issue to do with PCI recognition but you get a very specific error message. There is a workaround, but I don't think you have this problem.
Try another PCI slot...
My YouTube channel
Reply 5 of 49, by georgeqgreg
Great. Don't tell me you uploaded that just for me! But if you did... thanks. Hopefully something will eventually work on at least the Pentium 4, which seems to have more stable PCI. (That... breathtaking crash notwithstanding.) (Edit: I just noticed the time, so I think I'll do that in the morning.)
Reply 6 of 49, by Mau1wurf1977
Hehe no I uploaded this recently. Just very slow at adding more, simply too busy. But more to come.
If you get a specific error message related to PCI let me know.
My YouTube channel
Reply 7 of 49, by boxpressed
I just did this a couple of days ago. My Turtle Beach Montego II was a Dell OEM. The Dell Montego II drivers worked (I installed on a Dell Optiplex GX1). Not sure if the Dell Vortex 2 is weird like the Dell SB Live.
Reply 8 of 49, by swaaye
The DisableBusDetection tweak works for i815. First hand experience.
The 2048 drivers are buggy in games. That's why 2041 is recommended as you saw on VOGONS Drivers. Or, I should say 2041 is the newest that works properly. Older drivers might be ok too, like the OEM drivers, but you'll probably lose A3D features as you go backward in time.
Reply 9 of 49, by georgeqgreg
That trick works on the i815, eh? Good to know, that's the computer I'm more concerned about the card working on. The P4P800S has a gameport on the motherboard just for starters...
Thanks for all the advice and support everyone, it looks like I'll be very busy most of today, so I probably won't get to try a lot of this too soon, but you can be sure I will.
Reply 10 of 49, by Mau1wurf1977
Haven't had any issues on my AOpen board with i815 b-step. I do remember that the Turtle Beach driver had an issue with Incoming. It would lock up after the first or second level.
My YouTube channel
Reply 11 of 49, by georgeqgreg
This is a COMPAQ board though. They did some... weird things.
Reply 12 of 49, by georgeqgreg
So, I tried it on the i815. I used the INF trick detailed in one of the earliest responses. It at first seemed not to do anything, but then I saw it setting up gameport and emulation drivers, and saw it load the tray. I was quite happy, so I plugged my sidewinder in and tried to install it... but it wasn't detected. So then I tried to test the card in dxdiag... which froze the computer. After rebooting, the card wasn't seen at all! Not even the BIOS can see it. Ok, so how much have I screwed up so far?
Reply 14 of 49, by georgeqgreg
Of course. I've been basically using the Pentium 4 to diagnose pesky cards. My sidewinder is receiving power from the game port if it means anything. Anyway, I still haven't got it to do anything on 98 on the newer computer.
Reply 15 of 49, by swaaye
Sounds like the card may be dieing. Have you tried it as the only PCI card installed, and in different PCI slots? Win9x can be a real pain about PCI stability.
It might even be worth trying a fresh install of 98SE with APM mode forced instead of ACPI. I assume 98SE is using ACPI mode on those motherboards. ACPI can cause more PCI headaches.
"setup /p i"
Reply 16 of 49, by georgeqgreg
I think it is in APM mode? I might have messed up drivers a bit though. I remember forever ago I tried to install this USB printer. It turned out that you had to actually plug it in during the installshield program. If you didn't it would be impossible to install at all and you'd have to format Windows 98. I think I eventually gave up and just did an XP dual boot for the printer. (My mother for some reason preferred the XP interface anyway.)
Anyway, looks like I'll be moving the card around a bit more. I really do hope I didn't kill it. 😒
Reply 17 of 49, by georgeqgreg
Moving it to another slot, it's detected by the motherboard. Trying to install the drivers again, it freezes for a bit, then finds gameports and all the nice stuff, then since I disabled the onboard audio the card's now what Windows tries to play system sounds on... and when it tries it crashes. I also saw it put the DOS emulator in my autoexec, since I have it set to boot to DOS. The DOS program gives an error of hardware not found or something else.
(You can probably HEAR me considering getting a SBPCI128. Or maybe a board with ISA!)
Reply 19 of 49, by georgeqgreg
I wanted to have a more definitive answer, so I burned Puppy Linux to a CD and used it to play a WAV of a USB drive through the Vortex2. Sounds great! I'd say the sound card works. Can't figure out the gameport in linux, but I'm guessing old game controllers aren't a huge priority in linux land.
Anyway, I'm obviously doing something as far as Windows 98 is concerned wrong.
