First post, by Kreshna Aryaguna Nurzaman
- l33t
So, I think I'm going to move my retro computers to horizontal, rack-mounted server chassis. There will be two identical racks under my desk (custom-built open rack whose height is no more than 70 cm); one for the retro computers, while another for HT receivers and amplifiers and the likes.
My primary concern is to save vertical space. Secondary concern is to simplify cabling.
I found that 3U is the minimum height for a horizontal server chassis to contain typical PC expansion cards. I just sampled two cards; one is Sound Blaster AWE 32, and another is nVidia GeForce GTX 280. Both cards' heights are exactly 11 centimeters (including the edge connector), while 3U is 13.3 cm thick. So I guess I can safely say that 3U server chassis should be able to contain all the cards I have (Diamond MonsterSound MX300, Voodoo5 5500, etc).
I have browsed ebay for 3U extended ATX (eATX) server chassis, and since eATX is 13" deep, then I guess I can safely assume that most 3U eATX chassis can contain expansion card as long as Sound Blaster AWE32. A quick glance on some chassis seems to confirm that.
So, it seems 3U eATX rack-mounted chassis is capable to contain retro system, even with full-length ISA cards like Sound Blaster AWE 32. However, perhaps there are things I overlook. I'd really appreciate any thoughts and warnings regarding to the plan.
By the way, the systems:
System I
Intel 440BX motherboard
Pentium III 500 MHz
3dfx Voodoo5 5500 AGP
3dfx Voodoo Graphics
Sound Blaster AWE 32 + Yamaha DB50XG
DOS/Windows 98 dual boot
System II
Intel 845PE ISA motherboard
Pentium 4 2.4 GHz
nVidia GeForce 6800 GT
3dfx Voodoo5 5500 PCI Mac
Sound Blaster AWE 64 Gold
Yamaha SW60XG
System III
A yet-to-be-built Windows XP legacy system. Still not sure about its hardware, at least until I have found the fastest yet most backward compatible GeForce card possible. Will be likely an SLI system with Sound Blaster X-Fi sound card.
So, no 286 and the likes. I think they will fit into server chassis without problems, but somebody please warn me if this plan won't work.
Many thanks.
Kreshna Aryaguna Nurzaman.
