First post, by AidanExamineer
I've got a Slot 1 motherboard, I think it's from a Compaq originally (Apollo w/ VIA Chipset?), with a 30-pin IDC socket, alongside 2 IDE 40 pin, 1 floppy 34 pin, and a 26 pin LPT.
Is this some kind of proprietary thing? I even ran it past the veterans at work and they hadn't heard of or seen it before. I Googled the hell out of it too, and I can find listings for 30 pin ribbon cables, but no information as to what it connects with. It's keyed (29 pins in two rows of 15) and has a notch for a keyed cable.
Any ideas?
Reply 1 of 6, by Stojke
If you mean something like that connector below the SLOT 1 on this image:
Probably that ATi interface cable or something like that (cant remember now).
Reply 2 of 6, by AidanExamineer
It's kind of hard from the low resolution, but that connector looks a bit longer than the one I'm seeing. Is that not a SCSI connector? It looks longer than the 34 pin floppy connector in the same photo.
Reply 5 of 6, by AidanExamineer
pewpewpew wrote:
YEEEEEESSSS! Phew! Thanks! Figured it had to be some proprietary thing, and sure enough: Compaq!
Reply 6 of 6, by shamino
I can't blame the PC manufacturers for using a ribbon cable for their front panel connections. It's a big improvement really. The standard ATX way of connecting those things is pretty ridiculous, and I bet it causes some end-user problems when something gets unplugged.
What I do hate though, is when they don't document what that ribbon connector's pinout is.
I wish ATX defined a standard pinout for that stuff, so we could all have a single connector for it. It's definitely a shortcoming.
