First post, by Ragh
In the past I've had a problem getting my AWE 64 to output sound when used in conjunction with a MPU card. That issue was solved by changing the SB's 330 port to 300. (See AWE 64 no sound with mpu-401 isa card in DOS).
Now, I've purchased an IBM PC 330 433sx (486sx 33 processor, 3x isa slots, etc.), similar to this one: http://mastodonpc.tripod.com/personal/6571-l3b.html to which I have transplanted the aforementioned ISA cards. I am having similar issues where the AWE doesn't want to output any sound and MIDI via the MPU card works as expected. I have tried to setup the sound blaster card to the same settings as in my previous PC, but to no avail.
The CTCU utility reports that there is a conflict when selecting DMA 1 (DMA 1 conflicts with System Device settings). I can select wither DMA 0 or 3. I can't possibly find out which device is using DMA 1. I can't find anything in the BIOS config and I've been fiddling with motherboard jumpers by looking at a schematic label attached to the inside of the computer case. The only jumper setting mentioned in that schematic is "DMA CH1 ECP", but it doesn't do anything to free DMA 1 afaik.
Any one here with an IBM PC 330 or similar having successfully setup this?
