First post, by vetz
So I have Edge3D 2200 card were the BIOS chip seems to have failed. I switched it out with a chip from a working 2200 and it now boots as it should.
My questions are:
1. Do anyone have the BIOS of a Edge3D 2200 card laying around?
2. How do I dump the BIOS if I need to? Preferably through software.
3. If it can't be dumped by software, then I got to dump with a EEPROM reader?
Reply 1 of 12, by keropi
It is 99.999% sure that the bios can be dumped with a programmer, from the pic here I can see the chip is a 27C256 150ns - an one-time-programmable device. Piece of cake 😀
edit:
maybe this utility can be used: https://www.wimsbios.com/ajzchips/index.php
VGA Savebios.zip Saves a 32KB ROM image of your VGA BIOS
Reply 4 of 12, by keropi
heh yeah, I like tinkering that's true 🤣
also bumping this thread in case anyone can provide a bios image for the nv1 vga 😀
Reply 5 of 12, by Stiletto
I was JUST thinking the same thing: great idea 😁
do the Fandango!" - Queen
Stiletto
Reply 6 of 12, by vetz
Here is the file I got from the software Keropi linked to:
https://dl.dropboxusercontent.com/u/57506833/ … ons/VIDBIOS.BIN
Openening the file in Notepad provides some readable parts, so it seems to be the real deal. Still have to test it though.
    VGA Savebios.zip
    353 Bytes
    89 downloads
    VIDBIOS.rar
    17 KiB
    98 downloads
    Edge 3D 2000 series BIOS
Reply 7 of 12, by Robin4
This is what i read in my minipro program:
IBM COMPATIBLE 10/24/95 MD EDGE 3D 2000 SERIES Vers. 1.00 (C) DIAMOND MULTIMEDIA SYSTEMS INC 1MB RAM INSTALLED 2MB RAM INSTALLED
Reply 8 of 12, by vetz
keropi wrote on 2014-11-24, 22:02:
I know I'm bumping an old thread here, but I got myself a TL866II-Plus and I tried to write the attached BIOS file to a M27C512-10F, but that didn't work. Also I pealed back the label on one of my cards and its a ST M27C256B-12F. I've ordered some of those (10F version) and I'll report back when I receive them.
Also the original BIOS works fine in the reader (which causes the card to not boot), this being a Japanese card I believe its for NEC PC's.
Reply 9 of 12, by keropi
vetz wrote on 2021-05-30, 09:54:
Did you fill the whole 27c512 space?
It is 64kbytes so do a "copy /b 32k.bin + 32k.bin 64k.bin" and write the 64k.bin in the 27c512 chip
Reply 10 of 12, by vetz
keropi wrote on 2021-05-30, 09:57:
No, I didn't. I'm just getting started with the TL866, so I assumed the software would handle this by itself.
Reply 11 of 12, by vetz
Can confirm this did the trick. The card now boots as it should 😀
