First post, by kpuchatek
I have broken Yamaha SW60XG - component EMI1 came off the board. I don't see a easy way to solder it again, so can somebody help me, if it is possible to replace it ? I think it is EMI filter (3 legs) with number 233, on +12V line, but could be special type. Or maybe I can shorter two power pins in place of EMI1 ? I checked EMI2, which is on +5V and it has two power pins (shorted) and ground. Without EMI1 now, there is no +12V on the card
