Reply 40 of 48, by devius
That looks like the KITT module (brain, computer, whatever...) when the car was almost destroyed, and they had to put it inside a portable enclosure until they could rebuild the car.
Reply 42 of 48, by JayCeeBee64
Rank Retired
Retired
ReeseRiverson wrote:
JayCeeBee64 wrote:
Probably a SuperDisk LS-120 drive, which is itself very interesting (never had one of those myself).
Yeah, I believe that's it there! I just never got to play with it. 🤣
You could unplug the standard floppy drive and plug in the LS-120 instead, just for kicks 🤣
My other desktop cases do have turbo buttons and lamps. Except one which is my 386 Packard Bell, and only has the turbo lamp. No button.
brostenen wrote:
devius wrote:
How do you switch turbo on and off then? 😕
Can't remember what system. Yet I clearly remember systems on wich turbo was applied through keyboard button combinations.
If it was during boot or when Dos ran, I simply can not remember anymore. (the bios reported how, during boot)
I believe my uncle's 486 Packard Bell used the Alt-S key combo to switch turbo on and off from the DOS prompt.
Ooohh, the pain......
Reply 43 of 48, by ReeseRiverson
Makes me wonder if I can use the drive as a standard boot floppy drive. Though yeah, I could do just that. 😀
Now you also make me think about my 386 Packard Bell, I need to get into the BIOS and write down the info before too long. So I can change out the original barrel battery before it causes problems. I've been EXTREMELY fortunate it hasn't done anything wrong so far.
Reply 44 of 48, by devius
LS-120 is supposed to be compatible with standard floppies, and I've seen the LS-120 option in the boot menu on some BIOSes. I never actually knew what a LS-120 was until I read this thread though.
Reply 45 of 48, by ReeseRiverson
Now that you brought that up, that sounds vaguely familiar, I may have seen that in some BIOS options myself. Though like you, never knew what it originally was for. 🤣
Reply 46 of 48, by oerk
It sounds like you are talking about something like this that I have: […]
oerk wrote:
I had a similar case with speakers, though mine had a turbo button, LCD display with three digits, 1/4" headphone out and two 1/4" mic ins (with separate level controls), from about 1994.
Anyone know about these? Would love to have one again.
Except I no longer have the LCD MHz screen. 😢
Nope, sorry, that's not it. But this thing looks awesome!
Reply 48 of 48, by furan
maybe https://www.ebay.com/itm/Vintage-AT-DESKTOP-T … 2-/173064012622
