First post, by LunarG
- Oldbie
Happy New Year everybody 😀
Right, I just wanted to ask if anybody happen to have the jumper manual for the motherboard mentioned in the subject title.
I'm not sure what manufacturer it is, but the model name is S486G, it's a VLB based motherboard, and http://motherboards.mbarron.net/manuals/486vlb3/s486g.zip appears to be broken for me.
This is a problem, as I need that manual 😒
If anybody has the jumper manual, or even a board like this, with known CPU jumper config that I can use as a reference photo, I would much appreciate it.
The CPU in mounted in the picture isn't configured, I just put it in there seeing as the DX2 is a pretty "safe bet" if I'm going to do some testing. I would expect the default settings of the board to be 33MHz bus and 5V. But who knows? 😁
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
