First post, by xeon3d
Hi. (BTW I'm new here, but been a lurker for a while).
Recently a local charity asked me to check out a room full of computers to see if any of them could be worked to get at least windows xp on them and be usable. They also wanted to repurpose the room where the computers were. After being there for a whole day my conclusion was that there wasn't really any usable computers there (for them at least) as the most recent computer was a 1.5 Ghz P4 with 256Mb of RAM. So after telling the person in charge of the (bad) news, I was told to keep what I wanted and the rest would be binned. Amongst a few white branded PCs, DELL Optiplexes and Compaq Presarios (White/Blue case) I got to bring home an IBM PS/1 Model 2133-642.
Amazingly it still works wonders, but I'm having quite some difficulty find info about it online. From the case itself it should have a 486SX @ 25Mhz, 4MB of RAM and a 170MB HDD, but after opening the case and having a quick look/pictures taken, I found out the following:
Now for the questions:
a) According to the same handbook website, the motherboard seems from a 2133A type machine even tho there is no reference of 2133A anywhere on the computer, is this common?
b) It also says that that motherboard should come with a 486SX so my guess is that this was upgraded?
c) Where is the cheapest place to get RAM / Cache chips for this?
d) Any tips of how to restore the metal casing? It has a bit of rust.
Thanks in advance, here are some pics for your viewing pleasure:
Reply 1 of 19, by Jolaes76
Welcome and have a nice time on board 😀
I have a mid range model PS/1, a 486 SX 25.
Yours might be a factory upgraded model, although these were not commonly upped to DX2 level (you'd want to use at least a heatsink with that processor)
those SIPP-like video RAM modules cost a fortune IF you can find them 🙁
A collection of drivers, see the bottom of the page for the 50 MB archive:
http://www.walshcomptech.com/selectpccbbs/
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 3 of 19, by retrofanatic
Awesome...Thanks for the link! I have a couple ps/2 systems myself that I need drivers for.
Reply 4 of 19, by xeon3d
Jolaes76 wrote:
Welcome and have a nice time on board :) […]
Thanks Jolaes76 😀 You wouldn't happen to have the original disks / images that it came with? I guess they should also work on mine. About the VideoRAM modules I guess I'll give it a search and see what comes up. I'll also look for the cache chips too.
Reply 5 of 19, by Jolaes76
Unfortunately, I don't have the original disks for my PS/1. I have not found other PS/1 floppy images yet. The basic stuff at the end of the page I linked in should get you started, though.
Reply 6 of 19, by chal.nikkal
I have a mid range model PS/1, a 486 SX 25. Yours might be a factory upgraded model, although these were not commonly upped to DX2 level (you'd want to use at least a heatsink with that processor)??
GuL
Reply 10 of 19, by xeon3d
Hi all, finally after this much time I managed to have some time to work on it again and here's my new findings:
- The motherboard is without a doubt this one: http://ps-2.kev009.com/eprmhtml/eprm/f281.htm
- There's no hdd image of the original software anywhere on the internet 🙁
- The original specs of my machine were: 486 sx25 / 4MB / 170MB HDD
- Here's a copy of the german autoexec.bat / config.sys original files: http://ps-2.kev009.com/eprmhtml/eprmx/h12210.htm
I've asked a friend of mine which is a designer to redo the back sticker on the case and mine was pretty degraded.
I've also dismantled it (and lost a couple of black screws in the process (stupid me), and I'm preparing to take care of some rust that got into it. Luckily the motherboard escaped 😀
Reply 11 of 19, by PCBONEZ
xeon3d wrote:
Well what I find strange is that everything on it points to be a 486sx 25. Model number, name on the plastic cover...
Quite possible a board from a different machine got transplanted into it.
Reply 12 of 19, by PCBONEZ
I have manufactured my own 30-pin SIPPs simply by soldering pins onto 30-pin SIMMs. It worked out well.
You do have to make sure it's the right kind of RAM and if it doesn't use 30-pin SIPPs then I don't have a solution.
Reply 13 of 19, by Jolaes76
For this expansion module, I am pretty sure one would need the a service level manual (for the correct pinout). The chips themselves, however, are standard DRAM just like those already surface-mounted on the motherboard. Theoretically, it is not an impossible task.
Reply 14 of 19, by PCBONEZ
I didn't need a tech reference because I had correct SIPPs to look at in the first socket. Made it easy.
I've seen different info for the video RAM for different revs of this board.
Some said 20-pin SIPP, some said 30-pin SIPP, some said 40-pin ZIP.
Reply 15 of 19, by xeon3d
Found the service manual for my machine here: http://ps-2.kev009.com/pccbbs/aptiva/63g2028.pdf . The board is a 2133A (not a normal 2133).
Now it seems I need to find some cache chips for it. According to the service manual they should be:
"If you are installing cache memory in a board with no cache memory previously
installed, install 128K or 256K as follows:
Bank 1 Add eight 28-pin modules: 32K × 8, 25 ns SRAM"
Anyone knows where I can source them?
Reply 16 of 19, by PCBONEZ
xeon3d wrote:
Found the service manual for my machine here: http://ps-2.kev009.com/pccbbs/aptiva/63g2028.pdf . The board is a 2133A (not a nor […]
Scavenge from other boards.
eBay
Electronics shops.
www.mouser.com/ProductDetail/IDT/71256S ... VQkCOw0%3d
www.mouser.com/ProductDetail/IDT/71256S ... 52b%2fE%3d
There are also Digikey and Farnell (aka: Element 14)
I dunno which is best where you are.
Reply 17 of 19, by xeon3d
Thanks for the links. Sadly I don't have any other boards that are worth scavenging.
According to this: http://ps-2.kev009.com/eprmhtml/eprm/f281.htm, U38 Cache Memory Tag Socket (128KB/256KB) is a socket equal to the cache ones, but it's marked as Tag Socket? I have no idea on what to put there.... 🙁
Also, does vogons have a marketplace?
Reply 18 of 19, by alexanrs
Nope, no sales or trading allowed here.
Anyway, that socket is probably for the tag RAM... Think of it as an index for the actual cache RAM. It should also be an SRAM IC, just like the rest of the cache. I don't know the capacity it needs for the 256KB of cache you want to put it, but another 32KB IC might do the job. Read the service manual throughly, as it should say how much tag RAM you should use.
Reply 19 of 19, by PCBONEZ
It's in your manual pages 188 & 189.
manual wrote:
1055—Cache Memory […]
1055—Cache Memory
Warning:
Memory cards are sensitive to static discharge. See “Handling ESD-Sensitive Parts” on page 4-47.
Cover (2005)
Adapter Card(s) (2035) if applicable
Riser Card (2045) if applicable.
Note:
Run the Configuration Utility after adding or removing memory.
If the system board has cache memory modules already installed, the computer has 128K of cache memory.
Upgrade to 256K by adding memory modules as follows:
Bank 2
Add four 28-pin modules: 32K×8, 25 ns SRAM.
Tag
Replace existing module with one 28-pin module: 32K×8, 20 ns SRAM.
If you are installing cache memory in a board with no cache memory previously installed, install 128K or 256K as follows:
Bank 1
Add four 28-pin modules: 32K×8, 25 ns SRAM (for 128K or 256K).
Bank 2
Add four 28-pin modules: 32Kx8, 25 ns SRAM (for 256K).
Tag
Add one 28-pin module: 32K×8, 20 ns SRAM (for 256K)
or 8K×8, 20 ns SRAM (for 128K)
So for 256k you need
- 8pc 32K×8, 25 ns
- 1pc 32K×8, 20 ns (for the Tag)
