First post, by Robin4
- l33t
I have two AT style cases here.. But i like to know which you guys would use for your 286 and 386 build..
The 286 would be a 12MHZ class machine with an option to set it to 16Mhz.
The 386 would be a DX 40MHZ class machine which would keep this speed..
The cases i have are:
This one is mine:
The original setup was a 486 DX 40MHz, VLB UMC chipset Processor was also an UMC one..
And the other case is:
I know the buttons are yellowed but can be fixed.
