First post, by Robin4
- l33t
Like to know if anyone ever have seen BGA chips on a DDR 1 ram stick? Because i received 4 sticks with BGA`s on it with these specs: they have samsung chips and are 1GB DDR1 PC3200 ones..
From what i can tell they do run great / fast on a very unstable picky MSI K8N NEO2 Platinum 2 motherboard.. Normally with PC3200 basic SMT sticks they wouldnt run 400Mhz on 1T with 2.5 cas.. But these stick will run fine if you raise the memory a little bit to 2.55 / 2.60volt.. And yes they are 4x 1GB sticks with a total of 4GB of memory.. Bios iam running is 1.C i think these bios is better then the 1.0D one..
Iam very happy with the result so far, it could be much worser.
