ISA MIDI Cards
First post, by DoomGuy II
I'm just curious to see if there are any ISA MIDI only cards out there. I do have a Sound Blaster 16 installed for DOS games. The problem is that while I can use the MIDI port of the 16 with no issue, I get the noticeable bugs with it, like sound issues with Duke 3D (have to set at 11025hz to prevent lag) and the fact that it stalls for a few more seconds before playing another MIDI track (at least in WinAmp). Though alongside the 16, I also have an Ensoniq Soundscape OPUS for MIDI only and works perfectly fine, except that it sometimes does not play external MIDI even when it's set to external routing. So, any suggestions on MIDI cards, or possibly any other ISA sound cards that could be used for MIDI only purposes?
Official Website: https://dg410.duckdns.org/
Reply 1 of 7, by badmojo
It's a tricky one - have you tried a AWE64? I've been messing around with AWE cards lately (What retro activity did you get up to today?) and think they're great, particularly the ability to load sounds fonts.
Reply 2 of 7, by JayCeeBee64
Rank Retired
Retired
Well, there's the Roland SCC-1 and Yamaha SW60XG, but both have become hard to find and pricey (I see an SCC-1 on eBay going for around $380 at present).
A more feasible option is to buy a Yamaha YMF715/YMF718/YMF719 sound card and disable everything except the MPU-401 port and use it for MIDI. Several VOGONS members have done this and it works reasonably well. You could also replace the SB16 with the Yamaha card and avoid the issues you're currently having (unless you're set on the SB16).
Ooohh, the pain......
Reply 4 of 7, by bjt
Also Voyetra/Midiman/Music Quest cards. I am a fan of the Voyetra as it uses a Roland chipset and is 100% compatible, unlike the other two. These should go a bit cheaper than the Roland cards.
SW60XG is cool but it doesn't have an external midi port.
I use a YMF718 card in one of my machines for a DB and external midi, it does work well. You just have to make sure the resources don't overlap with the SB16.
Reply 5 of 7, by DoomGuy II
Well, I've put the YMF719 card on order and should arrive within a few days. Here's hoping it'll work out. In the meantime, any chance I can get a hold of the drivers for Windows 95 and DOS?
Reply 7 of 7, by bristlehog
There are also Turtle Beach Maui and Malibu MIDI cards.
Hardware comparisons and game system requirements: https://technical.city
