First post, by Thraka
I've tried attaching a coin battery with holder through a CD audio cable on to the external battery header but it doesn't seem to be working correctly.
My motherboard: http://museum.ttrk.ee/th99/m/A-B/33179.htm
It says JP1 is external battery, but it also lists it as a jumperable area.
JP1
Battery type select internal
pins 2 & 3 closed
Battery type select external
Closed
CMOS memory clear
pins 3 & 4 closed
What confuses me is that there are only 3 pins, pin 2 is missing. So it looks like this: |0||
There is a place for where the barrel battery would have gone but the soldier looks brand new and perfect, as if there never was one.
My cable looks like this: +00- only two pins being used. Should I be doing this instead? +0-- But that seems like it would be bad because it would be triggering the clear the CMOS. At least I assume it would. Was pin 2 removed because the thing didn't come with a barrel battery or something? Very odd.
Reply 1 of 5, by firage
The missing pin is there to key the battery connector. On my board the external battery connects +/Missing pin/NC/-
My big-red-switch 486
Reply 2 of 5, by Thraka
That's what I figured. So I have the same setup, +/missing/nothing/- but with it connected I had a CMOS error a few hours after being powered off.
I'm getting 2.9 volts out of the battery, seems like it should be enough.
Reply 3 of 5, by Maeslin
That's actually most likely dead for a button cell. No-load voltage for a new one is ~3.2-3.4V
Best way to check is voltage under load, with a 100Ohm resistor hooked to the battery while measuring.
Reply 4 of 5, by Billyray520
On my 386 board, which I switched from a soldered in barrel battery to a coin cell (CR2032) I used 2 cells in series (giving me 6v.) I also had the problem where after a few hours I would still lose the CMOS. Turned out I had to ground the negative lead to the case. Then everything worked perfectly.
Retro stuff owned since new
  • 386 20Mhz 2MB DOS 3.3/PC-MOS 4.0
  • AMD 386 40Mhz 32MB Win 3.11 DOS 5.0
  • 486DX-2 66Mhz 128MB Win 95b
  • PIII 450Mhz 768MB Win 98SE
  • PIV 2Ghz 2GB Win XP/Ubuntu 10
Reply 5 of 5, by Thraka
I checked the negative pin with a continuity test to the negative soldier point on the barrel battery and they connected. Don't know if that makes a diff.. 😀 However, I posted another thing about my floppies not being recognized so I may just have to junk the board.. 🙁
