Have tested a crapload of my other GF4 (and other) cards on the slot1 mobo, partly on request from the seller to investigate some more.
NONE of these other cards showed any sign of artifacting in the exact same hardware and software configuration. (no drivers installed, apart from those included in WinXP SP1)
After some more re-testing, the faulty Ti4600 Sparkle card now has changed behaviour 'somewhat'. Maybe because of all the action/reboots etc heating it(chips) up and/or perhaps 'charging' the caps ?
- At POST, before starting booting into WinXP, the artifacts now don't appear anymore, but as soon as the harddrive initiates windows, there is a (different) pattern emerging, all the way until system tries to show the desktop, then it totally explodes into a massive mess, like a black&white version of the Stars and Stripes. Then goes into an automatic reboot(!) after a few seconds.
If I then leave it unattended, it will repeat this whole process indefinately (while adding a disk check stage because of the reboots)...........
For the record, if then I turn it all off, and just swap the Sparkle GF4 card for any other card, it is all perfectly fine again! (after the obligatory disk check) - I don't have to change or do anyting else, neither in software or hardware.
The easy culprit to blame would be WindowsXP, but... it does NOT happen with ANY of my other cards, so.... back to faulty memory then.
Maybe the previous owner did not test further than POST (?).
But he has confirmed that "the card was working perfectly the day he removed it to photograph for eBay".
Which may indicate it was in an actual working PC (with an OS?) at the time ?
- Oh well, regardless it seems like the local recycling plant is the most likely recipient, as I just cannot get this to work properly nomatter what I do, and all my other similar cards show none of these problems in the exact same setting... 😢
