First post, by Runicen
- Newbie
I'm still in the early stages with this piece of hardware, but I wanted to cast around for some information in the meanwhile.
As part of a recent hardware haul, I ended up with an ISA Sound Blaster 16 (CT2980). My older PC has its line out run into stereo inputs on my Akai EIE I/O Pro DAC, which then sends the signal to my speakers.
I had been using a Yamaha Audician via the same setup and had pretty decent luck with it once I figured out how to set the jumpers to disable the onboard amp and render the output a line out. Unfortunately, though the SB16 has a slightly smaller memory footprint, the signal I'm getting from it - either line out or speaker out - is dirty and incredibly low in level. This may just be the card itself as I know a lot of folks on the board have nothing positive to say about these boards, but I wasn't sure if reduced output on that level (I almost have to max out the pre-amps and level of the Akai to get it to a listenable level) is a sign that the caps have or are going bad on the board.
Visually, nothing is wrong with it - no bulges or leaks. It just seems odd that the output would be so weak AND that the Roland daughterboard I have on it would be turning out such incredibly low MIDI relative to the digital sound.
The first step is for me to pull the thing out and check jumper configuration, but if it IS the caps, how hard is it to swap the caps out on one of these cards? I've never done it before, but I'm assuming due to the relatively low number of caps on an SB16, it's as good a place to start as any. Can anyone offer any pointers? How about poly modding?
