Great PC! But can it run Crysis?
Reply 160 of 241, by SPBHM
9500PRO and P4 2.4@3GHz
281.52 KiB
the thing the makes it feel the worst is the ram amount the PC have (768MB DDR333 single channel), the first run was pretty bad with all the loading.
but realistically Crysis as a game gets much heavier near the end, so it would be interesting to test the game there, I could see the card not managing 10FPS, but, maybe I'm wrong and low is really very easy even there.
edit: this is another level of bad, between the weak GPU and the PCI (not PCIE) bus it couldn't go well
284.46 KiB
Reply 161 of 241, by agent_x007
9800 XT + PDC 4GHz :
315.3 KiB
Simply put : 128MB is just not enough for higher details/res.
Also, here's Pentium 4 score (on Full HD resolution 😉) :
364.7 KiB
Reply 162 of 241, by squareguy
It runs 😀
460.22 KiB
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 163 of 241, by havli
Radeon HD 3870 @ DX9 1280x1024 high settings.
Phenom X4 9650
2 GB DDR2 800 Mhz
Gigabyte GA-MA785GM-US2H
Windows 7 x64
Radeon HD 3870 -> 31.8 fps
Reply 164 of 241, by agent_x007
Same settings, but on AGP system :
QX 9770 @ 3,84GHz (FSB = 256MHz)
4GB 800MHz CL5.5.4.12 CR2T [~3GB usable]
ASRock 4CoreDual-SATA2 R2 (BIOS L2.20)
Radeon HD 3850 AGP (715/1818)
Windows XP SP3
@Last Run :
Avg. 32,75 FPS
Min. 17.76 FPS
388.17 KiB
Reply 165 of 241, by havli
Impressive score for an AGP system. 😎 Sure, QX9770 is completely different animal compared to 2.3GHz 65nm Phenom but this benchmark shouldn't be CPU limited, not at 30 fps anyway. 😀 Perhaps Win XP is faster or older Catalyst are better suited for RV670.
Reply 166 of 241, by agent_x007
Thanks 😀
QX 9770 @ 3,84GHz/256MHz FSB (stock is 3,2GHz with 50% higher FSB 😜)
But back on topic : Your setup has serious problems with min. FPS.
Not enough RAM maybe (since CPU bottleneck isn't an option) ?
PS. After changing AGP GPU for PCI-e (with x4 PCI-e speed)...
Side note : PCI-e cards add ~500MB of RAM to usable pool of ~3,4GB.
Radeon HD 5870 1GB (850/4800) :
Avg. 82,22FPS,
Min. 42,71FPS
308.06 KiB
Since that's... kinda high for "High" settings - I upped resolution to Full HD, added MSAA x4 on top and run the test again 😉
Result :
Avg. 55,01FPS
Min. 38,24FPS
337.62 KiB
Reply 167 of 241, by matze79
Anyone still has the Guru3D Crisis Benchmark ?
Download link is broken.
Reply 168 of 241, by matze79
Running Crysis:
220.35 KiB
Something does prevent choosing medium, crysis crashes every time using any setting higher then low.
1280x1024 is pretty heavy for this Machine.
Crysis Demo runs ok at 800x600, and is playable.
15.12 KiB
The Phenom 1 has Performance Problems.. with TLB Bug 7zip performs worse as example. (BIOS Bugfix enabled.)
Reply 169 of 241, by SPBHM
is that an IGP or discrete card?
I almost bought a Chrome 440 GTX once (lost the auction on the last second), would be interesting to test those, I remember them being competent against the low end AMD/Nvidia at the time (8400GS/HD2400)
in any case even the C7 is probably to slow with any VGA, a Via Nano based system would probably do a lot better! still, impressive that it "runs" 😎
Reply 170 of 241, by matze79
Its a discrete PCI Express Card, the Chrome S25.
The Card is only Shader Model 2.0 and offers GeForce 6600 Performance Levels.
The S27 should faster it features DDR3 Ram.
I never saw a Nano or Nano X2 or Nano Quadcore System..
The Boards are very expensive and not avaible in germany 😀
Reply 171 of 241, by clueless1
Poor GTX 750Ti being held back by 2.67Ghz C2D with stodgy Intel motherboard. Don't judge, it's the best I've got ATM.
262.88 KiB
Reply 172 of 241, by Munx
1.79 MiB
No hardware to properly max it at the time of release, that's for sure...
EDIT: Just realized I had the memory in single channel, Fixed 😀
Not that it helped much.
1.83 MiB
My builds!
The Underdog - The budget K6
Reply 174 of 241, by elianda
I changed from GTX780 SLI to Titan X Pascal and my score in this bench lowered. Something is scaling not right or maybe it's even on a fast i7 3930K CPU fully limited.
Youtube Channel
Reply 175 of 241, by MrEWhite
Yeah, the XP is being bottlenecked if your doing it at 1080p with that CPU (I think)
Reply 176 of 241, by lazibayer
14.96 FPS
AMD A10-7860K @ 3.6GHz, ASRock FM2A78-ITX+, 2x8GB DDR3-2400 @ 10-12-12-31, integrated GPU & audio, Server 2012 R2.
CryEngine2 keeps crashing in 32bit mode so I had to run it in 64bit mode.
    270.81 KiB
Reply 177 of 241, by elianda
Yeah well the 3930K is running at 4.3 GHz and it would mean that already with GTX780 SLI Crysis was running 100% CPU bottlenecked.
Youtube Channel
Reply 178 of 241, by buckeye
Intel Core i7 2600
Geforce GTX 1050Ti
    290.16 KiB
